digi303
(Carsten)
1
Hello
I am trying to create a maintenance schedule in home assistant. I have realised this via input.datetime.
I would now like to reset this to the current date using a tap action. Unfortunately, I cannot do this.
I always get the error message:
could not parse date for dictionary value @ data[#date].
what am I doing wrong?
Here is my config:
tap_action:
action: call-service
service: input_datetime.set_datetime
service_data:
entity_id: input_datetime.clean_break_group
date: '{{ now().strftime(' '%Y-%m-%d' ') }}'
tom_l
2
Using templates in Lovelace. Pretty much only the markdown card supports that.
Call a script that resets your helper or use this custom card and JavaScript templates:
digi303
(Carsten)
3
thanks. So nothing wrong but not implemented
I will use a script then.
Do you have a solution for your Problem?
I want to add a day to my datetime Helper, by using service.
Its working well in automations, but not in the UI
- type: tile
entity: sensor.datetime_next_bobby_cleaning
show_entity_picture: false
vertical: false
name: nächste Reinigung (Klick zum Überspringen)
tap_action:
date: >-
{{ (as_datetime(states('input_datetime.datum_nachste_bobby_reinigung')) +
timedelta(days=1)).date() }}
entity_id: input_datetime.datum_nachste_bobby_reinigung
