Hi all,
I have three Sonoff ZBMINIs installed inside electric outlets in my home, so they are not easily accessible.
I am in the process of switching from a Deconz (using Conbee 2) to Zigbee2MQTT (using a SONOFF Zigbee 3.0 Dongle). Both dongles are attached and running on a RPi 4 with Home Assistant OS.
According to this manual you need to push a button on the ZBMINI for 5 seconds to factory reset it and put it into pairing mode. I would like to avoid this, since the device are not easily accessible.
Does anyone know, if I can send command through the Phoscon/Deconz to put the devices into pairing mode? I have tried removing them from Phoscon, but was unable to pair it with Zigbee2Mqtt. Interestingly though, I was able to re-pair it with the Conbee 2 network after it did not work with Zigbee2Mqtt …
