How to reset total energy value on PZEM-004T V1 (8S)?
How to reset total energy value on PZEM-004T V1 (8S) ?
https://esphome.io/components/sensor/pzem004t.html?highlight=pzem
It’s doesn’t works …
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "***********"
  password: "***********"
  ap:
    ssid: "Wattmetre Fallback Hotspot"
    password: "**********"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
  port: 80
# Example configuration entry
uart:
  tx_pin: D6
  rx_pin: D7
  baud_rate: 9600
  stop_bits: 1
  - platform: pzem004t
    current:
    voltage:
    power:
      name: "PZEM-004T Puissance"
    energy:
    update_interval: 10s
# Temps de fonctionnement
  - platform: uptime
    name: "Allumé depuis (s)"
  - platform: wifi_signal
    name: "Puissance Signal WiFi"
    update_interval: 60s
text_sensor:
  - platform: version
    name: "Allumé depuis (j)"
    lambda: |-
          int seconds = (id(uptime_sec).state);
          int days = seconds / (24 * 3600);
          seconds = seconds % (24 * 3600);
          int hours = seconds / 3600;
          seconds = seconds % 3600;
          int minutes = seconds /  60;
          seconds = seconds % 60;
          return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
    icon: mdi:clock-start
switch:
  - platform: restart
    name: "Redemarrage Wattmetre"
  - platform: uart
    name: "PZEM-004T Energy Reset"
    data: [0x01, 0x42, 0x80, 0x11]
binary_sensor:
  - platform: status
    name: "Etat du Wattmetre"
Thanks for your support.
