I am running Home Assistant OS version 10.5 (core 2024.1.6) on an RPI 3. I want to trigger an action by typing a key on my USB keyboard. This is what I do:
I connect my keyboard to one of the USB ports and try to find the device name: ls /dev/input/by-id
It gives me this line: lrwxrwxrwx 1 root root 9 Apr 4 2023 usb_keyboard-event-kbd -> ../event0
So I should use the device /dev/input/event0. Someone wrote that it is possible to to read directly from the port (I am the “root” user): cat /dev/input/event0
Then I get the message Operation is not permitted.
Maybe this is normal. I don’t know, so I continue to set upp the Keyboard Remote integration in configuration.yaml:
Although I don’t know how that would work on HAOS, you can try trough the device_name
$ sudo evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0: 2.4G Composite Devic
/dev/input/event1: 2.4G Composite Devic Mouse
/dev/input/event2: 2.4G Composite Devic Consumer Control
/dev/input/event3: 2.4G Composite Devic System Control
/dev/input/event4: Power Button
/dev/input/event5: Power Button
/dev/input/event6: PC Speaker
/dev/input/event7: HDA Digital PCBeep
/dev/input/event8: HDA Intel PCH Front Mic
/dev/input/event9: HDA Intel PCH Rear Mic
/dev/input/event10: HDA Intel PCH Line
/dev/input/event11: HDA Intel PCH Line Out Front
/dev/input/event12: HDA Intel PCH Line Out Surround
/dev/input/event13: HDA Intel PCH Line Out CLFE
/dev/input/event14: HDA Intel PCH Front Headphone
Select the device event number [0-14]:
There is no evtest utility in HASS OS, so I installed it by: apk add evtest
When I run sudo evtest I get evtest: Operation not permitted
Is there another way to find the device name?
Is there a problem with the HASS OS configuration? Is it running in a docker container? Does that change the way I have to address issues with USB ports?
It suddenly started working when I rebooted my RPI. My mistake was that I selected Developer tools > YAML > YAML Configuration reloading > All YAML Configuration
after each change in the configuration.yaml file.
That was apparently not enough. I suspect that some information in the yaml files are only read when restarting the system.
