Sometimes an integration will fail to start up. I noticed that in this case there seems to be no option to reload the integration in the menu (see screenshot). As a result I have to restart Home Assistant entirely to get the integration to load. Is there any easier way to attempt reloading an integration that failed to start? It seems odd that only successfully loaded integrations get the reload option since it’s the failed ones you are most likely wanting to retry.
Many thanks,
Tom
