Z2M
Info 2024-04-08 21:23:39MQTT publish: topic 'zigbee2mqtt/Ventilation Suite Parentale', payload '{"battery":100,"delay":0,"last_seen":"2024-03-28T12:56:02+01:00","linkquality":156,"lower":93,"mode":"switch","program":{"0":255,"1":255,"2":255,"3":0},"reverse":"ON","state":"OFF","touch":"ON","upper":6}'
Info 2024-04-08 21:23:39MQTT publish: topic 'zigbee2mqtt/0xa4c1386f7c870cbe', payload '{"battery":93,"comfort_humidity_max":0.6,"comfort_humidity_min":0.4,"comfort_temperature_max":0.25,"comfort_temperature_min":0.2,"enable_display":"OFF","humidity":52.61,"humidity_calibration":null,"last_seen":"2024-04-08T21:19:25+02:00","linkquality":40,"show_smiley":"HIDE","temperature":22.27,"temperature_calibration":null,"temperature_display_mode":"celsius","update":{"installed_version":18886657,"latest_version":18886657,"state":"idle"},"update_available":false}'
Debug 2024-04-08 21:23:44Received Zigbee message from 'Prise Piscine', type 'readResponse', cluster 'seMetering', data '{"currentSummDelivered":[0,0]}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:44MQTT publish: topic 'zigbee2mqtt/Prise Piscine', payload '{"child_lock":"UNLOCK","current":0,"energy":0,"indicator_mode":"off/on","last_seen":"2024-04-08T21:23:40+02:00","linkquality":153,"power":0,"power_outage_memory":"restore","state":"OFF","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":231}'
Debug 2024-04-08 21:23:44Received Zigbee message from 'Prise Sèche Linge', type 'attributeReport', cluster 'genBasic', data '{"65506":54,"65508":0,"appVersion":192}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:44MQTT publish: topic 'zigbee2mqtt/Prise Sèche Linge', payload '{"child_lock":"UNLOCK","current":0,"energy":19.93,"indicator_mode":"off","last_seen":"2024-04-08T21:23:41+02:00","linkquality":54,"power":0,"power_outage_memory":"restore","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":234}'
Debug 2024-04-08 21:23:44Received Zigbee message from 'Prise Bureau Mélanie Dessin', type 'attributeReport', cluster 'genBasic', data '{"65506":54,"65508":0,"appVersion":192}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:44MQTT publish: topic 'zigbee2mqtt/Prise Bureau Mélanie Dessin', payload '{"child_lock":"UNLOCK","current":0,"energy":0.29,"indicator_mode":"off/on","last_seen":"2024-04-08T21:23:42+02:00","linkquality":94,"power":0,"power_outage_memory":"restore","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":231}'
Debug 2024-04-08 21:23:44Received Zigbee message from 'Prise Aspirateur Cuisine', type 'attributeReport', cluster 'genBasic', data '{"65506":54,"65508":0,"appVersion":192}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:44MQTT publish: topic 'zigbee2mqtt/Prise Aspirateur Cuisine', payload '{"child_lock":"UNLOCK","current":0,"energy":1.71,"indicator_mode":"off/on","last_seen":"2024-04-08T21:23:43+02:00","linkquality":43,"power":0,"power_outage_memory":"restore","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":232}'
Debug 2024-04-08 21:23:44Received Zigbee message from 'Prise Chargeur Tablette Entrée', type 'read', cluster 'genTime', data '["time"]' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:44MQTT publish: topic 'zigbee2mqtt/Prise Chargeur Tablette Entrée', payload '{"consumption":26.34451675415039,"device_temperature":35,"energy":26.34,"last_seen":"2024-04-08T21:23:43+02:00","linkquality":142,"power":0.76,"power_outage_count":111,"power_outage_memory":null,"state":"ON","temperature":37,"update":{"installed_version":92,"latest_version":92,"state":"idle"},"update_available":false}'
Debug 2024-04-08 21:23:47Received Zigbee message from 'Prise Lave Linge', type 'attributeReport', cluster 'genBasic', data '{"65506":54,"65508":0,"appVersion":192}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:47MQTT publish: topic 'zigbee2mqtt/Prise Lave Linge', payload '{"child_lock":"UNLOCK","current":0,"energy":38.04,"indicator_mode":"off","last_seen":"2024-04-08T21:23:44+02:00","linkquality":32,"power":0,"power_outage_memory":"restore","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":234}'
Debug 2024-04-08 21:23:47Received Zigbee message from 'Capteur Mouvement Hall Entrée', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":2}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:47MQTT publish: topic 'zigbee2mqtt/Capteur Mouvement Hall Entrée', payload '{"battery":100,"device_temperature":24,"illuminance":2,"illuminance_lux":2,"last_seen":"2024-04-08T21:23:44+02:00","linkquality":127,"occupancy":true,"power_outage_count":52,"temperature":26,"voltage":3035}'
Debug 2024-04-08 21:23:47Received Zigbee message from 'Capteur Mouvement Hall Entrée', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:47MQTT publish: topic 'zigbee2mqtt/Capteur Mouvement Hall Entrée', payload '{"battery":100,"device_temperature":24,"illuminance":2,"illuminance_lux":2,"last_seen":"2024-04-08T21:23:44+02:00","linkquality":131,"occupancy":true,"power_outage_count":52,"temperature":26,"voltage":3035}'
Debug 2024-04-08 21:23:47Received Zigbee message from 'Capteur Mouvement Salle de Jeux', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":93}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:47MQTT publish: topic 'zigbee2mqtt/Capteur Mouvement Salle de Jeux', payload '{"battery":100,"device_temperature":25,"illuminance":93,"illuminance_lux":93,"last_seen":"2024-04-08T21:23:45+02:00","linkquality":91,"occupancy":true,"power_outage_count":53,"temperature":27,"voltage":3025}'
Debug 2024-04-08 21:23:47Received Zigbee message from 'Capteur Mouvement Salle de Jeux', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:47MQTT publish: topic 'zigbee2mqtt/Capteur Mouvement Salle de Jeux', payload '{"battery":100,"device_temperature":25,"illuminance":93,"illuminance_lux":93,"last_seen":"2024-04-08T21:23:45+02:00","linkquality":94,"occupancy":true,"power_outage_count":53,"temperature":27,"voltage":3025}'
Debug 2024-04-08 21:23:47Received Zigbee message from 'Prise Canapé Salle à Manger', type 'read', cluster 'genTime', data '["time"]' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:47MQTT publish: topic 'zigbee2mqtt/Prise Canapé Salle à Manger', payload '{"consumption":548.042724609375,"device_temperature":35,"energy":548.04,"last_seen":"2024-04-08T21:23:45+02:00","linkquality":87,"power":0.99,"power_outage_count":132,"power_outage_memory":true,"state":"ON","update":{"installed_version":92,"latest_version":92,"state":"idle"},"update_available":false}'
Debug 2024-04-08 21:23:47Received Zigbee message from 'Prise Multimédia Suite Parentale', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":1}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:47MQTT publish: topic 'zigbee2mqtt/Prise Multimédia Suite Parentale', payload '{"action":null,"last_seen":"2024-04-08T21:23:46+02:00","led_if_on":"ON","led_in_dark":"ON","linkquality":94,"power":1,"power_apparent":54,"power_on_behavior":"previous","state":"ON","update":{"installed_version":5129215,"latest_version":5456895,"state":"available"},"update_available":true}'
Debug 2024-04-08 21:23:47Received Zigbee message from 'Capteur Mouvement Salon', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":6}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:47MQTT publish: topic 'zigbee2mqtt/Capteur Mouvement Salon', payload '{"battery":83,"device_temperature":27,"illuminance":6,"illuminance_lux":6,"last_seen":"2024-04-08T21:23:46+02:00","linkquality":83,"occupancy":true,"power_outage_count":85,"temperature":30,"voltage":2975}'
Debug 2024-04-08 21:23:47Received Zigbee message from 'Capteur Mouvement Salon', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
Debug 2024-04-08 21:23:47Received Zigbee message from 'Prise Cuisine Été Friteuse', type 'readResponse', cluster 'seMetering', data '{"currentSummDelivered":[0,758]}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:47MQTT publish: topic 'zigbee2mqtt/Prise Cuisine Été Friteuse', payload '{"child_lock":"UNLOCK","current":0,"energy":7.58,"indicator_mode":"off/on","last_seen":"2024-04-08T21:23:47+02:00","linkquality":91,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":234}'
Debug 2024-04-08 21:23:48Received Zigbee message from 'Capteur Mouvement Escalier', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":0}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:48MQTT publish: topic 'zigbee2mqtt/Capteur Mouvement Escalier', payload '{"battery":100,"device_temperature":26,"illuminance":0,"illuminance_lux":0,"last_seen":"2024-04-08T21:23:48+02:00","linkquality":142,"occupancy":true,"power_outage_count":36,"temperature":28,"voltage":3025}'
Debug 2024-04-08 21:23:48Received Zigbee message from 'Capteur Mouvement Escalier', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
Debug 2024-04-08 21:23:51Received Zigbee message from 'Prise Bureau Mélanie Devoirs', type 'readResponse', cluster 'seMetering', data '{"currentSummDelivered":[0,58]}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:51MQTT publish: topic 'zigbee2mqtt/Prise Bureau Mélanie Devoirs', payload '{"child_lock":"UNLOCK","current":0.09,"energy":0.58,"indicator_mode":"off/on","last_seen":"2024-04-08T21:23:51+02:00","linkquality":91,"power":10,"power_outage_memory":"restore","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":232}'
Debug 2024-04-08 21:23:51Received Zigbee message from 'Prise Multimédia Suite Parentale', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":2}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:51MQTT publish: topic 'zigbee2mqtt/Prise Multimédia Suite Parentale', payload '{"action":null,"last_seen":"2024-04-08T21:23:51+02:00","led_if_on":"ON","led_in_dark":"ON","linkquality":94,"power":2,"power_apparent":54,"power_on_behavior":"previous","state":"ON","update":{"installed_version":5129215,"latest_version":5456895,"state":"available"},"update_available":true}'
Warning 2024-04-08 21:23:52Failed to ping 'Prise Garage Atelier Soudure' (attempt 1/2, ZCL command 0x60a423fffe13a933/11 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Timeout - 47871 - 11 - 177 - 0 - 1 after 10000ms))
Debug 2024-04-08 21:23:53Received Zigbee message from 'Capteur Mouvement Hall Étage', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":0}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:53MQTT publish: topic 'zigbee2mqtt/Capteur Mouvement Hall Étage', payload '{"battery":90,"device_temperature":29,"illuminance":0,"illuminance_lux":0,"last_seen":"2024-04-08T21:23:53+02:00","linkquality":91,"occupancy":true,"power_outage_count":69,"temperature":32,"voltage":2985}'
Debug 2024-04-08 21:23:53Received Zigbee message from 'Capteur Mouvement Hall Étage', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:53MQTT publish: topic 'zigbee2mqtt/Capteur Mouvement Hall Étage', payload '{"battery":90,"device_temperature":29,"illuminance":0,"illuminance_lux":0,"last_seen":"2024-04-08T21:23:53+02:00","linkquality":94,"occupancy":true,"power_outage_count":69,"temperature":32,"voltage":2985}'
Debug 2024-04-08 21:23:55Received Zigbee message from '0xa4c1386f7c870cbe', type 'attributeReport', cluster 'msTemperatureMeasurement', data '{"measuredValue":2235}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:55MQTT publish: topic 'zigbee2mqtt/0xa4c1386f7c870cbe', payload '{"battery":93,"comfort_humidity_max":0.6,"comfort_humidity_min":0.4,"comfort_temperature_max":0.25,"comfort_temperature_min":0.2,"enable_display":"OFF","humidity":52.61,"humidity_calibration":null,"last_seen":"2024-04-08T21:23:55+02:00","linkquality":43,"show_smiley":"HIDE","temperature":22.35,"temperature_calibration":null,"temperature_display_mode":"celsius","update":{"installed_version":18886657,"latest_version":18886657,"state":"idle"},"update_available":false}'
Debug 2024-04-08 21:23:56Received Zigbee message from 'Prise Garage Atelier Soudure', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 11 with groupID 0
Info 2024-04-08 21:23:56MQTT publish: topic 'zigbee2mqtt/Prise Garage Atelier Soudure', payload '{"indicator_mode":"off/on","last_seen":"2024-04-08T21:23:55+02:00","linkquality":91,"power_on_behavior":"off","state":"OFF"}'
Debug 2024-04-08 21:23:56Successfully pinged 'Prise Garage Atelier Soudure' (attempt 2/2)
Debug 2024-04-08 21:23:58Received Zigbee message from 'Prise Sèche Linge', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":0,"rmsCurrent":0,"rmsVoltage":233}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:58MQTT publish: topic 'zigbee2mqtt/Prise Sèche Linge', payload '{"child_lock":"UNLOCK","current":0,"energy":19.93,"indicator_mode":"off","last_seen":"2024-04-08T21:23:58+02:00","linkquality":47,"power":0,"power_outage_memory":"restore","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":233}'
Debug 2024-04-08 21:23:59Received Zigbee message from 'Prise Sèche Linge', type 'attributeReport', cluster 'seMetering', data '{"currentSummDelivered":[0,1993]}' from endpoint 1 with groupID 0
Info 2024-04-08 21:23:59MQTT publish: topic 'zigbee2mqtt/Prise Sèche Linge', payload '{"child_lock":"UNLOCK","current":0,"energy":19.93,"indicator_mode":"off","last_seen":"2024-04-08T21:23:58+02:00","linkquality":47,"power":0,"power_outage_memory":"restore","state":"ON","update":{"installed_version":192,"latest_version":192,"state":"idle"},"update_available":false,"voltage":233}'
Debug 2024-04-08 21:23:59Received Zigbee message from 'Contacteur Fenêtre Lena', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":3025,"10":15997,"100":0,"3":25,"4":17320,"5":26,"6":[0,1]}}' from endpoint 1 with groupID 0
Debug 2024-04-08 21:23:59MCCGQ11LM: Processed data into payload {"voltage":3025,"battery":100,"device_temperature":25,"power_outage_count":25,"trigger_count":0,"contact":true}
Info 2024-04-08 21:23:59MQTT publish: topic 'zigbee2mqtt/Contacteur Fenêtre Lena', payload '{"battery":100,"contact":true,"device_temperature":25,"last_seen":"2024-04-08T21:23:59+02:00","linkquality":105,"power_outage_count":25,"temperature":29,"trigger_count":0,"voltage":3025}'
Debug 2024-04-08 21:24:01Received Zigbee message from 'Prise Lampe Bureau', type 'read', cluster 'genTime', data '["time"]' from endpoint 1 with groupID 0
Info 2024-04-08 21:24:01MQTT publish: topic 'zigbee2mqtt/Prise Lampe Bureau', payload '{"consumption":17.75301170349121,"device_temperature":39,"energy":17.75,"last_seen":"2024-04-08T21:24:01+02:00","linkquality":36,"power":5.47,"power_outage_count":104,"power_outage_memory":true,"state":"ON","temperature":32,"update":{"installed_version":92,"latest_version":92,"state":"idle"},"update_available":false}'
Debug 2024-04-08 21:24:03Received Zigbee message from 'Prise Veilleuse Laura', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 11 with groupID 0
Info 2024-04-08 21:24:03MQTT publish: topic 'zigbee2mqtt/Prise Veilleuse Laura', payload '{"indicator_mode":null,"last_seen":"2024-04-08T21:24:03+02:00","linkquality":105,"power_on_behavior":"previous","state":"ON"}'
Debug 2024-04-08 21:24:03Successfully pinged 'Prise Veilleuse Laura' (attempt 1/2)
Debug 2024-04-08 21:24:06Received Zigbee message from 'Relai Lumières Cuisine Eté Bar et Salle Eau', type 'read', cluster 'genTime', data '["time"]' from endpoint 1 with groupID 0
Info 2024-04-08 21:24:06
