The presence sensors are mostly Sonoff, now I have moved lighting back to Hue I only have one presence sensor working now.
Running zigbee2MQTT 1.37.0-1
Ok finally resolved this issue by completely removing zigbee2MQTT while I was switching to a POE / Ethernet connected zigbee SMLight coordinator.
It was a pain having to re-pair 80 odd devices, not as bad as it could have been if I had not already moved all the 80+ lights and motion sensors onto Hue Hubs.
All the issues I was having with zigbee2MQTT,
zigbee2MQTT failed to re-start after a Home Assistant reboot
Every 5-10 days zigbee2MQTT would initially make all devices unresponsive followed by declaring them offline.
Interesting. I am having this exact same issue (unavailable after restarts) and i have just recently moved to a SMLight coordinator from the old sonoff usb one i had. The entities migrated fine but im guessing there is something underlying that is causing all the issues. Thanks for posting!
Sweet! Its surviving restarts now that i repaired everything.
Hi everyone!
I run into sort of the same problem as others here.
I have HA running in Docker, as well as the Mosquitto broker and Zigbee2MQTT
When I manually restart Home Assistant all the devices provided by Zigbee2Mqtt work fine.
But after a Home Assistant update (executed by watchtower) none of the devices work. They all remain on unavailable.
The only way to get them back up is to restart the Zigbee2Mqtt container.
I already checked if the birth and will status’ are correctly configured and that is the case.
Does anyone have a solution to this?
Thanks in advance!
Edit: It doesnt work when homeassistant is offline for more than a couple of moments. When I turn it off for 3 minutes everything remains unavailable. If I just do a restart it does work fine.
I did read the full thread and I am running z2m with ha on raspberry pi5 and from 2 weeks, z2m does not restart on ha restart. Did I missed something? Nothing in the logs of z2m it is stopped.
Running as an add-on? Add-ons don’t get restarted on a HA restart, only on a host reboot, or by a manual restart of the Add-on.
Ha it did for month. ![]()
As addon yes
or this automation :
- id: '1565194745362'
alias: Status starting HA
- event: start
platform: homeassistant
- service: hassio.addon_restart
addon: 45df7312_zigbee2mqtt
Yes thanks. Manual restart is what I want to avoid. Can try the automation. But it was working before.
Koenkk wrote me this: z2m will only reset it if the ha integration is enabaled and legacy_action_sensor is true
