I’m looking for some help. I believe the type of HA I’m running is called Core, unsupervised.
I had been running a version of HA that I had last updated in September of 2022. End of December, I upgraded to the latest December 2022 version out there. This update seemed to break my setup. After reboot, the built in weather integration would break and not work. Reboot would have it work again for 10-15 mins, and it would become ‘unavailable’. Openweather I believe it is.
At this point, I was just going to roll back my install to my last full backup, from September of 2022. Problem I had, none of my backups would show up within HA. The files are there, I backed them up to my PC via Samba share. HA was so laggy or buggy that various parts wouldn’t load, which included backups pane.
I waited, and sure enough January 2023 releases came out. I updated to the first one and still experienced the weather issues and other stuff not loading, or breaking until I would reboot my Raspberry Pi that hosts my install.
Then the latest January 2023 came out and that seems to have fixed all of my loading issues. Weather now works continuously. No more needing to reboot. The kicker - NONE of my backups show up now in the interface. I am able to perform a NEW backup and see that, but I can’t see any of my old ones (prior to Jan 2023).
I wanted to add the Google Drive Home Assistant Backup thing to my install, and can’t figure out how to add the respository. Add-On Store is missing now, with no way to add it. I also see notification for:
The following integrations and platforms could not be set up:
- hassio ([Show logs]
- raspberry_pi ([Show logs]
Was the Add-On Store removed sometime between last year and now? I think I want to roll back to September 2022 backup, but don’t know how to do this, since I can’t view older backups in the interface. Were older backups somehow blocked from being able to revert back to? It’s like HA closed down outside support, removed the add on store with ability to add repositories.
What are my options here? Running on a RaspPi 4. I have all of my old backups on my PC. Would I need to find an older image of HA, reinstall from scratch, upload my old 9-2022 backup to it, and then kick off a restore?
