How to Retrieve Historical Energy Consumption Data from Woox R6118 Smart Plug with Energy Meter in Home Assistant?
I’m currently using a Woox R6118 Smart Plug with Energy Meter and have integrated it with Home Assistant via the Tuya integration. While everything is working well, I’ve run into a problem: the energy consumption data that shows up in Home Assistant only reflects the values recorded after the integration was set up. All historical data from before the connection seems to be missing.
I initially connected the plug to the Woox app, and later switched to the Tuya app for better integration with Home Assistant. Interestingly, the energy consumption history is still available in the Tuya app, showing data from the time the plug was connected to Woox App. This suggests that the data might be stored locally on the plug.
Here’s my question:
Is it possible to retrieve the historical energy consumption data from the Woox R6118 Smart Plug in Home Assistant?
I’ve checked the Tuya integration, but it seems to only fetch data from the moment the plug was integrated with Home Assistant. I’m wondering if there’s a way to access the plug’s internal memory or get the historical data that’s visible in the Tuya app or the Woox app but not in Home Assistant.
Thanks in advance for your help!
