Im trying to setup a local tuya garage door switch as a lock
it has a sensor that detects the door contact state but this is reversed so its false when closed and true when opened
is there a way to reverse this? i would like it to require a pin to open via google assistant and atm it only needs a pin to close it which is not very helpful
The Spook integration has a inverse helper.
I had a look at Spook but its not able to inverse locks only switches
I was able to do this by creating a new lock template to reverse the states and actions
lock:
value_template: >-
{% if is_state('lock.smart_garage_door_opener_garage_door', 'unlocked') %}
locked
{% else %}
unlocked
{% endif %}
lock:
action: lock.unlock
entity_id: lock.smart_garage_door_opener_garage_door
unlock:
action: lock.lock
entity_id: lock.smart_garage_door_opener_garage_door`Preformatted text`
