I’ve searched the forums and I’m just not seeing any solutions that don’t involve installing a ton more components.
Issue: my octoprint camera is upside down and I would like to rotate it
most of the guides and threads are out of date and don’t apply anymore, or the other common “solution” is installing HACS and then something to edit the card it’s on. i’m not understanding the documention for that “fix” so i’m unable to apply it, also it seems somewhat of a shotgun-for-a-fly fix that i’d rather not implement.
for the smart asses in the room:
no, i can’t re-orient the camera
no, i’m not turning the printer upside down
no, i’m not turning my head to view it
the camera works fine in octoprint, but that’s POST manipulation of the stream, I can’t figure out how to modify the original stream
if my only solution is going the HACS route i guess I will, but that just seems to overkill for something that i would have thought would be simplier.
