How to round InfluxDB sensor values for the UI in 2023?
I want to display my DSL sync values in Home Assistant (pulled from InfluxDB). They should be shown in mbps and be rounded to 2 decimals. The rounding should only be done for the UI, so I don’t lose the precision on the underlying sensor. The following code does this by creating an extra template sensor to be used by the UI:
  - platform: influxdb
    ssl: false
    api_version: 2
    host: !secret influxdb_host
    port: !secret influxdb_port
    organization: !secret influxdb_organization
    token: !secret influxdb_token_default_ro
    bucket: default
    queries_flux:
      - group_function: last
        name: "DSL Downstream (kbps)"
        unique_id: dsl_downstream_kbps
        unit_of_measurement: kbps
        range_start: "-15m"
        query: >
          filter(fn: (r) => r["_measurement"] == "smart4_vdsl_status")
          |> filter(fn: (r) => r["_field"] == "dsl_downstream")
template:
  - sensor:
      - name: "DSL Downstream"
        unit_of_measurement: mbps
        state: "{{ (states('sensor.dsl_downstream_kbps') | float / 1024) | round(2) }}"
This works just fine, but I’m wondering if there is a way to avoid having the extra template sensor. I read that suggested_display_precision was recently introduced and I was hoping that I could do something like this in my InfluxDB sensor:
        value_template: "{{ value | float / 1024 }}"
        suggested_display_precision: 2
        range_start: "-15m"
        query: >
However, it looks like that this isn’t supported in the Influx integration (yet?).
So is the code I’m currently using still the best approach in 2023, or are there better alternatives (without using custom UI cards)?
Thanks,
Aaron
I just found out that is is possible to change this on the UI:
That’s pretty neat!
Still wondering if it’s possible to define this in YAML rather than going into each entity on the UI and set it up there?
