ashscott
(Ash)
September 20, 2021, 5:07pm
1
I need to be able to run a stepper motor until I want to stop it, rather than use a target position.
I can probably achieve this in a convoluted way using the cover component but it’s not a very tidy or efficient solution. And my device isn’t a ‘cover’!
Am I missing a simpler way?
ashscott
(Ash)
September 21, 2021, 8:46am
2
Having thought this through and worked on a couple of options, I’ve settled on the following utilising two scripts.
Not ideal due to the arbitrary target position, but at least gives on/off control.
binary_sensor:
- platform: homeassistant # Manual feeding from HA
entity_id: input_boolean.manually_feed_fish #defined in homeassistant
on_press:
then:
- script.execute: run_motor
on_release:
then:
- script.execute: stop_motor
script:
- id: run_motor
then:
- stepper.set_target:
target: 500 # Can be set to any value that exceeds typical design run time
- id: stop_motor
then:
target: !lambda return id(feed_motor).current_position;
- stepper.report_position:
position: 0
target: 0
paviro
June 15, 2022, 7:41pm
3
Just a quick note this is how I solved it so it really runs forever:
esphome:
on_loop:
then:
position: 0
globals:
- id: motor_running
type: bool
restore_value: no
initial_value: 'false'
stepper:
- platform: uln2003
pin_a: GPIO18
pin_b: GPIO14
pin_c: GPIO27
pin_d: GPIO21
max_speed: 300 steps/s
sleep_when_done: true
script:
- id: start_motor
then:
- lambda: 'id(motor_running) = true;'
target: 10
- id: stop_motor
then:
- lambda: 'id(motor_running) = false;'
target: 0
- id: toggle_motor
then:
- if:
condition:
lambda: 'return id(motor_running) == false;'
then:
- script.execute: start_motor
else:
So I basically just reset the reported position back to 0 every time the loop runs.
thanks for this @paviro can I ask how you then trigger the motor from homeassistant? to explain what I am trying to acheive, its running the motor for a catfeeder for x amounts of steps in the same direction each time I trigger an automation
paviro
September 14, 2022, 11:05am
5
I just use a switch:
switch:
icon: "mdi:rotate-360"
lambda: |-
if (id(motor_running)) {
return true;
} else {
return false;
turn_on_action:
turn_off_action:
But my goal is continues rotation. Maybe a service would be nicer in your case.
