How to run an automation that run on night
Hi all,
sorry for my stupid question.
I currently have a door sensor and a roller shutter
my first automation was : move the roller down at night => very easy as i used the sunset event :slight_smile:
my second automation was : move the roller down at night if the bay window isn’t open => still very easy as i simply added a condition that checks the door status
but now it came to my mind :
if i’m outside(the bay window is open), night begin and i’m still out, then i go in minutes or hours after sunset (i don’t know in advance this time)
how can i do automate that the roller should move down once the bay window is closed if outside is already night ?
or is the sunset still valid in middle of the night ?
I’m rather new at this myself, but I think you want the sensor for sun above horizon or below horizon. This would be true after the moment of sunset has passed.
Hope that helps.
for this you need 1 automation with 2 triggers and 2 conditions.
triggers: sunset and closing window
conditions: sun = below_horizon and window is closed.
I don’t want to steal the learning curve from you :wink: but do let me know if you need help
thanks that sound perfect, i’m going to try this :wink:
edit : for the door sensor it asks me to fill 3 fields
from
to
for
to close
for ?
to: 'off' (or whatever value means closed)
you don’t have to provide the other 2 , you need at least one
That’s for the trigger of course
ok thanks for the answer.
currently i have done following automation
sunset + bay window close => put down
door closed + after sunset => put down
week day at specific hour => put up
door opened + roller is down => put up
If i merge both first automation in one, wouldn’t it generate an issue
i mean if conditions are OR and trigger point are OR logic then
it would mean that I also allow
sunset trigger + after sunset condition => put down (and this is not something i want)
or is it possible to say condition 1 should only apply on trigger 1 and condition 2 on trigger 2
The sky’s the limit.
Conditions are AND by default, so as long as you want only AND conditions, simply list them one after the other.
check the docs for examples:
