Hi everyone, i need to save datas from HomeAssistant to create a sort of log where i have readings from selected sensor every x minutes in a format compatible with Excel (.csv, .xls, .xlsx or so).
I managed to do that with the Google Sheets integration, but i’d like to have a backup option that does not require internet acces (as HomeAssistant works in a network with a 4G router so it could drop sometimes) and so i’d need to save datas to a file in HomeAssistant or, if that’s not possible, to export existing datas from Home Assistant history into excel, selecting a period of time and frequency… do you know any solution that could work?
You can use the history-explorer-card in the frontend and here is a solution with a file notification.
Is there some default way to do this? Out of the box in the application?
Wait for 2024.2
Ooo neat. It’s native now! Here’s an updated link to the release notes:
