Hi, i have a global variable “ihell_dsip” which is predefined in globals and can be changed. Code is:
- id: ihell_disp # Displayhelligkeit der Zeit
type: int
restore_value: yes
initial_value: '80'
the way i can change this value manually is like:
number:
optimistic: true
min_value: 70
max_value: 128
step: 2
on_value:
- globals.set:
value: !lambda 'return x;' # x is the value from the input number
this all works fine,
BUT i want to keep the manually changed value AFTER REBOOT. I learned that in ESP8266 (which i am using) its needed to specify a pararameter in esp-section as follows:
esphome:
friendly_name: wemos-01
platform: ESP8266
board: d1_mini
esp8266_restore_from_flash: True
to restore the values. I did that…
But it always starts with the value 70.
I know that storing in EPROM is only every minute, so i waited long enough. But still no RESTORING.
Is there any more idea around ??
