How do you guys save the motor position so when the ESP reboots, it knows what position the stepper motor is at?
I have a stepper motor that rotates clockwise or counter clockwise depending on the value of a photoresistor. I’m trying to save the value of the position in the globals. But I can’t properly retrieve it.
I created two globals for the value of the steps depending on the value of the photoresistor.
- id: current_light
type: float
restore_value: no
# initial_value: '0'
- id: previous_light
type: float
restore_value: yes
initial_value: '0'
These globals I used to store the value of the photoresistor that I use to run the motor.
on_value:
then:
- globals.set:
value: !lambda return id(ambient_sensor).state;
- delay: 1s
- if:
condition:
switch.is_off: auto_light_enable_script
then:
- if:
condition:
or:
- lambda: return id(current_light) - id(previous_light) > 5.0;
- lambda: return id(current_light) - id(previous_light) < -5.0;
then:
- lambda: id(oled).turn_on();
- stepper.set_target:
target: !lambda return ((id(current_light) / 100) * id(endstop));
- globals.set:
value: !lambda return id(current_light);
else:
- lambda: id(oled).turn_off();
- stepper.report_position:
position: !lambda return ((id(previous_light) / 100) * id(endstop));
And this part is the entire automation. Here’s how it’s currently working – when the value of the resistor changes 5 levels higher or lower, the motor will turn either counter clockwise or clockwise depending on the value the photoresistor.
This works fine, but when the ESP reboots, I can’t get the motor to retrieve it’s position.
on_boot:
then:
- ds1307.read_time
- display.page.show: intro_page
- delay: 2s
- display.page.show: main_page
- delay: 5s
- globals.set:
#- lambda: id(oled).turn_on();
Here’s what I added in the on_boot: But I’m doing it wrong. When it boots the motor keeps on turning nonstop, until the value of the resistor changes.
My previous code was something like this:
on_boot:
target: !lambda return ((id(current_light) / 100) - (id(previous_light) / 100));
Basically the code above calculates the current light value against with the previous value and multiply it to endstop – endstop is the value of the max step of the motor.
For example. If the current value of the light is 1000 and the previous light value is 1000, result will be 0. But when the ESP reboots, the motor turns a complete 1000 steps. I can’t figure out why this is happening. Sometimes if the previous value is 750 and the current value is 1000, the motor rotates a full 1000 steps, then rotate another 250 for the result of the values. I don’t understand.
Another question – what’s the reason why the ESP reboots randomly after some time? – this is one reason why I want to retain the motor position. And also I wanna try using deep sleep with this.
