I have been using HA for over a year and am just starting to get into (for me) some more complex scripts. I have run into an issue with variable scope in a script and cannot seem to find a way out. My guess is that I am missing a concept in HA that might be more appropriate for solving my problem.
My script’s goal: I have a set of 14 shelves each of which has an RGBW light. I normally set the shelves to a set of static colors (often white but say a mix of red and green at Christmas). To make things more dynamic, I am trying to set up a script that will randomly select a shelf and temporarily change its color and then return it to its original color before choosing another shelf to change. I like to use transitions for the lights so that one is fading out to its original color as the new one is fading into its temporary color.
The issue: You can see my initial script below. It attempts to change a random shelf to green and then restore its color to what it was at the beginning. It works… up until it selects the same shelf twice in a row. With the transition, when the “new” shelf is selected to be the same as the last iteration, the “old” shelf (itself) is still holding its temporary color so now the “new” shelf believes its current color is green. This means that over time, the whole set of shelves turns to green.
The solution I see is to prevent the same shelf being selected twice in a row… but here I run up against variable scope. I tried to create a variable to save the index of the last selected light and then at the beginning of a new iteration ensure that the newly selected light is not the same as the last iteration. Of course, with YAML’s scoping, I cannot get a variable to do this.
Do you see any other way to ensure that the same shelf is not selected on two back-to-back iterations of the sequence?
alias: Test
variables:
shelves: |
'light.sculptureshelf_shelf_01',
'light.sculptureshelf_shelf_02',
'light.sculptureshelf_shelf_03',
'light.sculptureshelf_shelf_04',
'light.sculptureshelf_shelf_05',
'light.sculptureshelf_shelf_06',
'light.sculptureshelf_shelf_07',
'light.sculptureshelf_shelf_08',
'light.sculptureshelf_shelf_09',
'light.sculptureshelf_shelf_10',
'light.sculptureshelf_shelf_11',
'light.sculptureshelf_shelf_12',
'light.sculptureshelf_shelf_13',
'light.sculptureshelf_shelf_14'
sequence:
- repeat:
sequence:
- alias: Select Light
variables:
random_light: "{{ range(0, 13) | random }}"
- alias: Get current color
variables:
current_color: "{{ state_attr(shelves[random_light], 'rgbw_color') }}"
- alias: Turn on light
action: light.turn_on
rgbw_color:
- 0
- 255
- 0
- 0
transition: 5
entity_id: "{{ shelves[random_light] }}"
- delay:
hours: 0
minutes: 0
seconds: 20
milliseconds: 0
- alias: Turn off light
transition: 5
rgbw_color: "{{ current_color }}"
while: []
description: ""
