Currently I have a router TP-LINK Archer C6 AC1200 which can’t create VLAN - only guest network.
I would like to be secured in case of being hacked, spied on etc (devices in main network). Budget 200$
I’m considering:
putting all IoT devices into guest network. I don’t use guest network so it’s not a problem.
flashing current router with openwrt, then create VLANs
buying new router + switch + ap with VLAN support (TP-Link ER605 router, TL-SG2008P switch, EAP 110)
buying new sim card and creating hotspot from old phone and then put IoT devices into this network - crazy idea, almost for free, maybe not so bad?
I will use dedicated tablet for steering home assistant so I dont need to use my mobile phone for steering ligts etc (separted network is fine for me).
Not a good idea. This idea of a guest network is that it has access to the internet but not to the local network or other devices on the guest network.
An EdgeRouter X is incredibly cheap for the power it has. It requires some knowledge to configure though, there aren’t a lot of GUIs. A Ubiquiti AP AC Lite might be within your budget too, if you run the Unifi software on an existing server.
Sounds like a terrible idea. The wifi coverage will be awful and most cellular networks use CGNAT complicating remote access.
Viable idea but… unless you are quite familiar with VLANs you will probably end up making your network less secure.
I second that. I bought my last router (a while ago) specifically to be able to install OpenWRT on it.
Now, generally speaking, using VLAN’s is a recipe for headaches, imo.
Not sure what kind of hacking or spying the OP has in mind, but plain using SSL everywhere would mitigate 99.99% of those.
I understand not all IoT devices would/could be easily configured to go SSL (we are talking about local SSL within LAN, right?) So if SSL is not 100% feasible, and VLAN introduces headaches, what other options do we have?
Now, seriously, what spying/hacking do you think your Tuya plug will do?
Phone home, that’s sure, but that’s the base idea of cloud-based IoT (unless you manage to reflash it, ofc).
Until someone point me to an actual hacking example where a VLAN would have made a difference, it’s all FUD to me…
I suggest an older x86 computer with two Gigabit ports & install OPNsense as the router, buy a switch, & use your current router as an AP. It is what I use.
