How to see if an entities number has increased
EDIT: I came up with something, see edit at end of original post. Would still like other ideas.
I want to create a very simple flow, but can’t think of how to program it.
In the picture below, the Amazon Delivered state node is watching a sensor that increases with each piece of Amazon mail that is delivered, and is then reset to 0 at midnight. Every time the number INCREASES (ie, 0 to 1, 1 to 2, 2 to 3) I want to trigger ‘Alert Jims phone’. I do not want anything to trigger when it gets set back to 0 at midnight.
[{"id":"adf42c5585367382","type":"tab","label":"Mail","disabled":false,"info":"","env":[]},{"id":"311f27a9a4807c3a","type":"server-state-changed","z":"adf42c5585367382","name":"Amazon delivered","server":"ab3e2c53.e3491","version":5,"outputs":1,"exposeAsEntityConfig":"","entityId":"sensor.mail_amazon_packages_delivered","entityIdType":"exact","outputInitially":false,"stateType":"str","ifState":"","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":375,"y":390,"wires":[["1b61bf1beb511681"]]},{"id":"1b61bf1beb511681","type":"api-call-service","z":"adf42c5585367382","name":"Alert Jims phone","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"notify","service":"notify_jim","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\":\"\",\"message\":\"Picture test\",\"data\":{\"sticky\":\"false\",\"priority\":\"Normal\",\"ttl\":0,\"tag\":\"picture_test\",\"color\":\"blue\",\"image\":\"/api/camera_proxy/camera.mail_amazon_delivery_camera\"}}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":675,"y":390,"wires":[[]]},{"id":"ab3e2c53.e3491","type":"server","name":"AvilaSmartHome","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
Edit:
OK here is what i came up with but still interested in your thoughts.
So everyday at 12:01am it checks sensor (which the integration resets to 0 at midnight) and writes that value to a global variable. So global is basically set to 0 at midnight.
Then lets say we get a package at 9am. The package delivered state node will trigger and compare the current count (1) , to the value of the global (0). If current > global, it passes on to the alert node and then also changes the value of global to (1).
We get another package at 2PM. Same check applies, if current (2) > global (1), then pass. Rinse repeat.
[{"id":"adf42c5585367382","type":"tab","label":"Mail","disabled":false,"info":"","env":[]},{"id":"311f27a9a4807c3a","type":"server-state-changed","z":"adf42c5585367382","name":"Package delivered","server":"ab3e2c53.e3491","version":5,"outputs":2,"exposeAsEntityConfig":"","entityId":"sensor.mail_amazon_packages_delivered","entityIdType":"exact","outputInitially":true,"stateType":"num","ifState":"amazon_packages_delivered","ifStateType":"global","ifStateOperator":"gt","outputOnlyOnStateChange":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":180,"y":330,"wires":[["1b61bf1beb511681"],[]]},{"id":"1b61bf1beb511681","type":"api-call-service","z":"adf42c5585367382","name":"Alert Jims phone","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"notify","service":"notify_jim","areaId":[],"deviceId":[],"entityId":[],"data":"{\"title\":\"\",\"message\":\"Picture test\",\"data\":{\"sticky\":\"false\",\"priority\":\"Normal\",\"ttl\":0,\"tag\":\"picture_test\",\"color\":\"blue\",\"image\":\"/api/camera_proxy/camera.mail_amazon_delivery_camera\"}}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":435,"y":330,"wires":[["3e4bc36cf40f40b7"]]},{"id":"3e4bc36cf40f40b7","type":"change","z":"adf42c5585367382","name":"","rules":[{"t":"set","p":"amazon_packages_delivered","pt":"global","to":"msg.count","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":790,"y":360,"wires":[[]]},{"id":"f8a8ebb3a861eecc","type":"api-current-state","z":"adf42c5585367382","name":"Current package count","server":"ab3e2c53.e3491","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.mail_amazon_packages_delivered","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"count","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":490,"y":420,"wires":[["3e4bc36cf40f40b7"]]},{"id":"d13f064427e0b8e8","type":"bigtimer","z":"adf42c5585367382","outtopic":"","outpayload1":"ON","outpayload2":"OFF","name":"Trigger at 12:01am everyday","comment":"","lat":"45.307781","lon":"-93.577408","starttime":"0","endtime":"0","starttime2":"0","endtime2":"0","startoff":"1","endoff":"2","startoff2":0,"endoff2":0,"offs":0,"outtext1":"","outtext2":"","timeout":1440,"sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":"","month1":"","day2":"","month2":"","day3":"","month3":"","day4":"","month4":"","day5":"","month5":"","day6":"","month6":"","day7":"","month7":"","day8":"","month8":"","day9":"","month9":"","day10":"","month10":"","day11":"","month11":"","day12":"31","month12":"12","d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xday7":"","xmonth7":"","xday8":"","xmonth8":"","xday9":"","xmonth9":"","xday10":"","xmonth10":"","xday11":"","xmonth11":"","xday12":"","xmonth12":"","xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":false,"atstart":false,"odd":false,"even":false,"x":210,"y":420,"wires":[["f8a8ebb3a861eecc"],[],[]],"outputLabels":["on-off message","",""]},{"id":"ab3e2c53.e3491","type":"server","name":"AvilaSmartHome","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
I am currently contemplating the same, but instead of storing the previous value I figure just ignoring the value 0 would do the trick? If so, I think everything can be done in an event state node. I’m going to see if this works:
Let me know how that works. It’s so simple. I had to have tried it, but can’t definitively say I did. So who knows maybe it was so simple I overlooked it!
The way I described in my OG post has been working, but your way is much simpler if works.
JIC I will leave this here should anyone need to find if the number actually increased. Using jsonata we have access to the previous entity variable. This can be used by setting If state to jsonata with $entity().state > $prevEntity().state
