How to send an image as a file to a smartphone (a simple way)?
I have an automation which send a camera snapshot to my smartphone when a particular event occurs. For that I use “send a notification via mobile app” service with the snapshot attached. But this way I cannot zoom into the image (or just display it full screen) so I would like to be able to sent the snapshot as a file I can open with an image viewer on the smartphone.
I know I could send it through Telegram or Gmail but that seems a little bit complicated to configure (and may be overkill for just this use case). Is there an easy way to do this?
Thanks for any help.
Due to the fact that Telegram is not encrypted, I would not use it.
You can easily setup the signal integration and send pictures.
