How to send notifications for DWD weather warnings
Yeah, complete restart also Done.
Have you checked trace on that automation?
I found this, but I can’t really figure it out from the messages
for this I simply lack the experience regarding the understanding of what was programmed here. If you have time, maybe you can explain it to me.
You are getting error when evaluating input_number. Try to see what is the value of input_number in developer tool of HA.
this is what I see. Actual there is no warning from DWD
Can you maybe help me further?
I’ve tried that and got a notification every 15 minutes - can some1 please share a working solution
This is my copy paste of entire code related to DWD weather warning. You can copy paste it, create your sensors in integration and adjust it to your needs. I use Android and receive notifications only when warning conditions are changed. I also added very nice card configuration for that.
It is all working very good, you just need to replace warnwetter_stadt_xxx_current_warning_level and warnwetter_stadt_xxx_advance_warning_level with your DWD sensors. I think that stadt_xxx can be ignored (deleted) it is some obsolete property.
Of course you should also change this part notify.mobile_app_alan_s22 defining your mobile device.
I also added click actions opening my dashboard with all weather information where my card is also located /lovelace/weather, you can adjust it or remove that part.
If you want to cover more cities, just add more triggers in automation, this part:
  - platform: state
    entity_id:
      - sensor.warnwetter_stadt_xxx_current_warning_level
      - sensor.warnwetter_stadt_xxx_advance_warning_level
Compared to my previous posts, this code is refactored, tested and dynamic, covering multiple cities. If you want you can remove “advance warning” trigger, if you only want to monitor current weather.
If you restart HA or reboot the machine, warning notification will be repeated. That is because I replaced input_number with input_select and input_select cannot remember options that were added dynamically. I am using input_select to have everything stored in one place and it is now automation based not trigger based.
/homeassistant/configuration.yaml
input_select: !include input_selects.yaml
/homeassistant/input_selects.yaml
automation_notify_weather_warning_notification_state:
  options:
    - None
Automation
alias: "Notify: Weather warning"
description: >-
  Supporting multiple trigger entities. Helper input_select used.
  - platform: state
    entity_id:
condition:
  - condition: template
    value_template: "{{ trigger.to_state.state != 'unavailable' }}"
  - variables:
      change: 0
  - if:
        alias: Anzahl Warnungen prĂŒfen
        value_template: "{{ trigger.to_state.attributes.warning_count|trim |int >= 1}}"
    then:
      - repeat:
          count: "{{ trigger.to_state.attributes.warning_count|trim |int }}"
          sequence:
            - if:
                  alias: Warnung Ă€nderungen prĂŒfen
                  value_template: >-
                    {{ trigger.from_state.attributes["warning_" ~ repeat.index]
                    != trigger.to_state.attributes["warning_" ~ repeat.index] }}
              then:
                - variables:
                    change: 1
      - if:
          - condition: and
            conditions:
                alias: Warnungen Anzahl Ă€nderung prĂŒfen
                value_template: >-
                  {{ trigger.to_state.attributes["warning_count"] ==
                  trigger.from_state.attributes["warning_count"] }}
                value_template: "{{ change == 0 }}"
                value_template: >-
                  state_attr('input_select.automation_notify_weather_warning_notification_state',
                  'options') | select('eq', trigger.entity_id~'_sent') | list |
                  count == 1 }}
        then:
          - stop: No changes in warnings.
      - service: notify.mobile_app_alan_s22
          message: |-
            {% set count = state_attr(trigger.entity_id, 'warning_count') %}
            {% for i in range(count) %}
              {%- set description = state_attr(trigger.entity_id, 'warning_' ~ loop.index ~ '_description') %}
              {%- set time_start = (state_attr(trigger.entity_id, 'warning_' ~ loop.index ~ '_start')|as_timestamp(now()) )|timestamp_custom('%d.%m.%Y, %R', true, 'N/A') %}
              {%- set time_end = (state_attr(trigger.entity_id, 'warning_' ~ loop.index ~ '_end')|as_timestamp(now()) )|timestamp_custom('%d.%m.%Y, %R', true, 'N/A') %}
              {%- set weekday_start = (state_attr(trigger.entity_id, 'warning_' ~ loop.index ~ '_start')|as_timestamp(now().timestamp()) )|timestamp_custom('%w', true, now().weekday() )|int %}
              {%- set weekday_end = (state_attr(trigger.entity_id, 'warning_' ~ loop.index ~ '_end')|as_timestamp(now().timestamp()) )|timestamp_custom('%w', true, now().weekday() )|int %}
              {%- set headline = state_attr(trigger.entity_id, 'warning_' ~ loop.index ~ '_headline') %}
              {%- set level = state_attr(trigger.entity_id, 'warning_' ~ loop.index ~ '_level') %}
              {%- set color = state_attr(trigger.entity_id, 'warning_' ~ loop.index ~ '_color') %}
              <span style="color: {{ color }}">{{ headline|trim }} - Stufe {{ level }}</span>
              {{ ['Montag','Dienstag','Mittwoch','Donnerstag','Freitag','Samstag','Sonntag'][weekday_start-1] ~ ', ' ~ time_start ~ ' - ' ~ ['Montag','Dienstag','Mittwoch','Donnerstag','Freitag','Samstag','Sonntag'][weekday_end-1] ~ ', ' ~ time_end }} {{ description|trim }}
            {% endfor %}
          title: |-
            {% set region_name = state_attr(trigger.entity_id, 'region_name') %}
            DWD {{ region_name }} Wetterwarnung ({{ count }})
            subtitle: >-
              'warning_1_headline') %} {%- set level =
              state_attr(trigger.entity_id, 'warning_1_level') %} {{
            subject: >-
              headline|trim }} - Level {{ level }}
            url: /lovelace/weather
            clickAction: /lovelace/weather
            tag: weather_warnings_{{ trigger.entity_id }}
            group: >-
              Weather warnings {{ state_attr(trigger.entity_id,
              "region_name")|trim }}
            channel: Weather warning
            notification_icon: mdi:cloud-alert
            color: "{{ state_attr(trigger.entity_id, 'warning_1_color') }}"
            ttl: 0
            priority: high
            sticky: "true"
            persistent: true
            timeout: |-
              {%- set count = state_attr(trigger.entity_id, 'warning_count') %}
              {%- set max_time_end = 0 %}
              {%- set ns = namespace (max_time_end = 0) %}
              {% for i in range(count) -%}
                {%- set time_end = state_attr(trigger.entity_id, 'warning_' ~ loop.index ~ '_end')|as_timestamp() %}
                {% if ns.max_time_end < time_end -%}
                  {%- set ns.max_time_end = time_end %}
                {%- endif %}
              {% endfor %}
              {{ (ns.max_time_end - as_timestamp(utcnow())) | int }}
      - service: input_select.set_options
          entity_id: input_select.automation_notify_weather_warning_notification_state
          options: >-
            'options') | reject('contains', trigger.entity_id) | list +
            [trigger.entity_id~'_sent'] }}
    else:
      - if:
            value_template: >-
              {{ trigger.to_state.attributes.warning_count !=
              trigger.from_state.attributes.warning_count }}
        then:
              message: >-
                Die Wetterlage hat sich wieder normalisiert.
                {{trigger.to_state.attributes.warning_count}}
                {{trigger.from_state.attributes.warning_count}}
              title: >-
                DWD Entwarnung fĂŒr {{ state_attr(trigger.entity_id,
                group: >-
                color: null
                ttl: 0
                priority: high
                timeout: 7200
            enabled: false
              message: clear_notification
            enabled: true
              entity_id: >-
              options: >-
                'options') | reject('contains', trigger.entity_id) | list }}
mode: queued
max: 10
Card for the dashboard
type: custom:vertical-stack-in-card
title: WarnWetter (DWD)
cards:
  - type: markdown
    title: null
    content: >-
      {# Beginn: Letzte Aktualisierung #}
      {% set sensor_region_name ="warnwetter_stadt_xxx" %}
      {% set current_last_update = state_attr("sensor." ~ sensor_region_name ~
      "_current_warning_level", "last_update") %} {% set weekday_last_update =
      as_timestamp(current_last_update) | timestamp_custom("%w", True) | int %}
      Stand: {{
      ['Montag','Dienstag','Mittwoch','Donnerstag','Freitag','Samstag','Sonntag'][weekday_last_update-1]
      ~ ", " ~ as_timestamp(current_last_update) | timestamp_custom('%d.%m.%Y -
      %H:%M:%S') }}
      {# Ende: Letzte Aktualisierung #}
      {# Beginn: 1. Region #}
      {% set current_region_name = state_attr("sensor." ~ sensor_region_name ~
      "_current_warning_level", "region_name") %} {% set current_count =
      state_attr("sensor." ~ sensor_region_name ~ "_current_warning_level",
      "warning_count") %} {% set advance_count = state_attr("sensor." ~
      sensor_region_name ~ "_advance_warning_level", "warning_count") %}
      ****{{ current_region_name }}****
      {% if ((current_count == 0 or current_count == None) and (advance_count ==
      0 or advance_count == None)) %} <font color=#cccccc>Keine
      Warnungen</font>{% else %}
        {% for i in range(current_count) %}
          {% set headline = state_attr("sensor." ~ sensor_region_name ~ "_current_warning_level", "warning_" ~ loop.index ~ "_headline") %}
          {% set description = state_attr("sensor." ~ sensor_region_name ~ "_current_warning_level", "warning_" ~ loop.index ~ "_description") %}
          {% set instruction = state_attr("sensor." ~ sensor_region_name ~ "_current_warning_level", "warning_" ~ loop.index ~ "_instruction") %}
          {% set level = state_attr("sensor." ~ sensor_region_name ~ "_current_warning_level", "warning_" ~ loop.index ~ "_level") %}
          {% set time_start = state_attr("sensor." ~ sensor_region_name ~ "_current_warning_level", "warning_" ~ loop.index ~ "_start") %}
          {% set weekday_start = as_timestamp(time_start) | timestamp_custom("%w", True) | int %}
          {% set time_end = state_attr("sensor." ~ sensor_region_name ~ "_current_warning_level", "warning_" ~ loop.index ~ "_end") %}
          {% set weekday_end = as_timestamp(time_end) | timestamp_custom("%w", True) | int %}
          {% set color = state_attr("sensor." ~ sensor_region_name ~ "_current_warning_level", "warning_" ~ loop.index ~ "_color") %}
        **<font color={{ color }}>{{ headline }} (Stufe {{ level }})</font>**
        **{{ ['Montag','Dienstag','Mittwoch','Donnerstag','Freitag','Samstag','Sonntag'][weekday_start-1] ~ ", " ~ as_timestamp(time_start) | timestamp_custom('%H:%M') ~ " Uhr - " ~ ['Montag','Dienstag','Mittwoch','Donnerstag','Freitag','Samstag','Sonntag'][weekday_end-1] ~ ", " ~ as_timestamp(time_end) | timestamp_custom('%H:%M') ~ " Uhr" }}**
        *{{ description|trim }}*
        {% if (instruction|trim != "None") %}
        ****{{ instruction|trim }}****
        {% endif %}
        {% if not loop.last %}***{% endif %}
        {% endfor %}
        {% if ((current_count != 0) and (advance_count != 0)) %}***{% endif %}
        {% for i in range(advance_count) %}
          {% set headline = state_attr("sensor." ~ sensor_region_name ~ "_advance_warning_level", "warning_" ~ loop.index ~ "_headline") %}
          {% set description = state_attr("sensor." ~ sensor_region_name ~ "_advance_warning_level", "warning_" ~ loop.index ~ "_description") %}
          {% set instruction = state_attr("sensor." ~ sensor_region_name ~ "_advance_warning_level", "warning_" ~ loop.index ~ "_instruction") %}
          {% set level = state_attr("sensor.sensor." ~ sensor_region_name ~ "_advance_warning_level", "warning_" ~ loop.index ~ "_level") %}
          {% set time_start = state_attr("sensor." ~ sensor_region_name ~ "_advance_warning_level", "warning_" ~ loop.index ~ "_start") %}
          {% set time_end = state_attr("sensor." ~ sensor_region_name ~ "_advance_warning_level", "warning_" ~ loop.index ~ "_end") %}
          {% set color = state_attr("sensor." ~ sensor_region_name ~ "_advance_warning_level", "warning_" ~ loop.index ~ "_color") %}
        **<font color={{ color }}>{{ headline }}</font>**
        {% endif %}
        {% endfor %}
      {% endif %}
      {# Ende: 1. Region #}
Thank you @alanmilinovic . I am trying to find a solution cause my entitiy names are these
  • sensor.dwd_weather_warnings_[IDNUMBER]aktuelle_warnstufe
    -sensor.dwd_weather_warnings
    [IDNUMBER]_vorwarnstufe
so i changed your stuff. lovelace is working.
is your notification only working for companion app?
Welcome.
You can replace my entity names with your names and it should work. Only trigger part of automation is place where change is needed.
Yes I am using notifications from companion apps. Should also work for iPhone, but I never tested it.
More info here: Introduction | Home Assistant Companion Docs
I also found a solution - it’s not the easiest one for sure, but it works and double notifications for one specific topic are very rare. What it basically does is building a “unique ID” based on several information from the warning and checks if something has changed.
The message also shows in which timespan the warning is issued. One example would be:
Von 18:00 Uhr bis morgen 10 Uhr: Es tritt Frost auf ...
In the following code, you just need to adjust the entities in the trigger section (and maybe also the texts from German to English):
# | Sends notifications for DWD weather warnings.            |
- alias: Benachrichtigung bei DWD-Wetterwarnungen
  description: Sendet Benachrichtigungen fĂŒr DWD-Wetterwarnungen
  mode: single
    - platform: state
      entity_id:
        - sensor.dwd_city_current_warning_level
        - sensor.dwd_city_advance_warning_level
      for:
        hours: 0
        minutes: 1
        seconds: 0
      alias: Auslösen, wenn sich das DWD-Warnlevel fĂŒr City Ă€ndert
  condition:
    - condition: state
      entity_id: input_boolean.disable_notification_automation
      state: "off"
      alias: Nicht ausfĂŒhren, wenn Benachrichtigungen deaktiviert wurden
    - condition: state
      entity_id: input_boolean.disable_warning_automations
      state: "off"
      alias: Nicht ausfĂŒhren, wenn Warnungen deaktiviert wurden
      value_template: >-
        {%- set ns = namespace(warnings = [], new_warnings = 0) -%}
        {%- set old_warning_count = trigger.from_state.attributes['warning_count'] -%}
        {%- for i in range(old_warning_count) -%}
          {%- set warning_index = i + 1 -%}
          {%- set old_warning_id = trigger.from_state.attributes['region_id'] | string -%}
          {%- set old_warning_id = old_warning_id + '-' + trigger.from_state.attributes['warning_' + warning_index | string + '_type'] | string -%}
          {%- set old_warning_id = old_warning_id + '-' + trigger.from_state.attributes['warning_' + warning_index | string + '_level'] | string -%}
          {%- if trigger.from_state.attributes['warning_' + warning_index | string + '_instruction'] -%}
            {%- set old_warning_id = old_warning_id + '-' + trigger.from_state.attributes['warning_' + warning_index | string + '_instruction'] | trim | length | string -%}
          {%- else -%}
            {%- set old_warning_id = old_warning_id + '-0' -%}
          {%- endif -%}
          {%- set old_warning_id = old_warning_id + '-' + trigger.from_state.attributes['warning_' + warning_index | string + '_start'] | string -%}
          {%- set old_warning_id = old_warning_id + '-' + trigger.from_state.attributes['warning_' + warning_index | string + '_end'] | string -%}
          {%- set ns.warnings = ns.warnings + [ old_warning_id ] -%}
        {%- endfor -%}
        {%- set new_warning_count = trigger.to_state.attributes['warning_count'] -%}
        {%- set new_warnings = 0 -%}
        {%- for i in range(new_warning_count) -%}
          {%- set new_warning_id = trigger.to_state.attributes['region_id'] | string -%}
          {%- set new_warning_id = new_warning_id + '-' + trigger.to_state.attributes['warning_' + warning_index | string + '_type'] | string -%}
          {%- set new_warning_id = new_warning_id + '-' + trigger.to_state.attributes['warning_' + warning_index | string + '_level'] | string -%}
          {%- if trigger.to_state.attributes['warning_' + warning_index | string + '_instruction'] -%}
            {%- set new_warning_id = new_warning_id + '-' + trigger.to_state.attributes['warning_' + warning_index | string + '_instruction'] | trim | length | string -%}
          {%- else -%}
            {%- set new_warning_id = new_warning_id + '-0' -%}
          {%- endif -%}
          {%- set new_warning_id = new_warning_id + '-' + trigger.to_state.attributes['warning_' + warning_index | string + '_start'] | string -%}
          {%- set new_warning_id = new_warning_id + '-' + trigger.to_state.attributes['warning_' + warning_index | string + '_end'] | string -%}
          {%- if not new_warning_id in ns.warnings -%}
            {%- set ns.new_warnings = ns.new_warnings + 1 -%}
          {%- endif -%}
        {%- endfor -%}
        {{- ns.new_warnings >= 1 -}}
      alias: Nicht ausfĂŒhren, wenn es keine Änderungen gab
    - repeat:
        count: '{{ state_attr(trigger.entity_id, "warning_count") | trim | int }}'
        sequence:
          - if:
              value_template: >-
                {%- set ns = namespace(warnings = []) -%}
                {%- endfor -%}
                {%- set new_warning_id = new_warning_id + '-' + trigger.to_state.attributes['warning_' + repeat.index | string + '_type'] | string -%}
                {%- set new_warning_id = new_warning_id + '-' + trigger.to_state.attributes['warning_' + repeat.index | string + '_level'] | string -%}
                {%- set new_warning_id = new_warning_id + '-' + trigger.to_state.attributes['warning_' + repeat.index | string + '_instruction'] | trim | length | string -%}
                {%- set new_warning_id = new_warning_id + '-' + trigger.to_state.attributes['warning_' + repeat.index | string + '_start'] | string -%}
                {%- set new_warning_id = new_warning_id + '-' + trigger.to_state.attributes['warning_' + repeat.index | string + '_end'] | string -%}
                {{ not new_warning_id in ns.warnings }}
              alias: PrĂŒfen, ob sich Warnung verĂ€ndert hat
            then:
              - service: notify.mobile_app_dominiks_iphone
                  message: >-
                    {%- set warning_timespan = '' %}
                    {%- set warning_start = trigger.to_state.attributes['warning_' + repeat.index | string + '_start'] | as_local %}
                    {%- set warning_start_day = warning_start.strftime('%Y%m%d') | int %}
                    {%- set warning_end = trigger.to_state.attributes['warning_' + repeat.index | string + '_end'] | as_local %}
                    {%- set warning_end_day = warning_end.strftime('%Y%m%d') | int %}
                    {%- set current_day = now().strftime('%Y%m%d') | int %}
                    {%- if warning_start > now() %}
                      {%- if (warning_start_day - current_day) == 0 %}
                        {%- set warning_timespan = 'Von ' %}
                      {%- elif (warning_start_day - current_day) == 1 %}
                        {%- set warning_timespan = 'Von morgen ' %}
                      {%- elif (warning_start_day - current_day) == 2 %}
                        {%- set warning_timespan = 'Von ĂŒbermorgen ' %}
                      {%- elif (warning_start_day - current_day) >= 3 %}
                        {%- set warning_timespan = 'Von ' + warning_start.strftime('%d.%m.%Y') + ' ' %}
                      {%- endif %}
                      {%- set warning_timespan = warning_timespan + warning_start.strftime('%H:%M') + ' Uhr bis ' %}
                    {%- else %}
                      {%- set warning_timespan = 'Bis ' %}
                    {%- endif %}
                    {%- if (warning_end_day - current_day) == 1 %}
                      {%- set warning_timespan = warning_timespan + 'morgen ' %}
                    {%- elif (warning_end_day - current_day) == 2 %}
                      {%- set warning_timespan = warning_timespan + 'ĂŒbermorgen ' %}
                    {%- elif (warning_end_day - current_day) >= 3 %}
                      {%- set warning_timespan = warning_timespan + warning_end.strftime('%d.%m.%Y') + ' ' %}
                    {%- endif %}
                    {%- set warning_timespan = warning_timespan + warning_end.strftime('%H:%M') + ' Uhr: ' %}
                    {{ warning_timespan }}
                    {{ trigger.to_state.attributes['warning_' + repeat.index | string + '_description'] | string }}
                    {%- if trigger.to_state.attributes['warning_' + repeat.index | string + '_instruction'] %}
                    {{ trigger.to_state.attributes['warning_' + repeat.index | string + '_instruction'] | string }}
                    {%- endif %}
                  title: "{{ trigger.to_state.attributes['warning_' + repeat.index | string + '_headline'] | string }}"
                    group: dwd_weather_warnings
                alias: Dominiks App ĂŒber die Wetterwarnung benachrichtigen
Maybe this also helps you :slight_smile:
best regards,
Dominik
@dominik4545 your solution looks also as good as @alanmilinovic .
Difficult to decide
Mine is better. :grinning:
