I’m testing Nabu Casa integration and I’m wondering how to configure the mobile app to send updates to my HA even when outside local network.
I enabled the webhooks but I’m not sure how to use them with the app. The remote UI also works properly and I can access it via web browser. The mobile app works only in LAN or via VPN. E.g. the battery and location is updated only when in LAN.
My goal is to send sensor updates not only when I’m home but also outside of my LAN. Is such thing possible? How to achieve that? I’d appreciate any help.
The companion apps for iOS and Android both send their sensor data to your HA server using the same Nabu Casa URL. It sounds like you just need to configure it in the app settings.
If you re-install the app while your device is on the same network as your HA server, and your NC remote is active, it will be automatically detected and entered for you. But you can also add it yourself in the app settings.
