The title pretty much explains what I am trying to do - without having to create more automations which is really overkill, one to assign the input_boolean as on and one to assign it as off etc., etc… The most elegant way would be to assign the value to the input_boolean right within the value template code snippet for that command line sensor where I could have a line of logic or two to search the command line text received for the specific string - but I’m having a little trouble figuring out the exact syntax… I have other ridiculously long command_line value templates that read the values of other sensors to calculate the value needed, so I am sure it can be done(?)… To keep the question specific, here is the current command line sensor value, between the quotes (it’s text most of which I will use in the front end):
“Oct 5 11:36:50 kruse-pi fancontrol.py: Fan Switched OFF; CPU Temp just fell below 55 to 54.53, (range is 55-65, checked every 5 seconds)”
The embedded string from the above that should be used to determine the input_boolean value will always have either the exact characters “Fan Switched OFF” or “Fan Switched ON”.
The input boolean entity is named “input_boolean.rpi_fan_running”.
Here is the current configuration.yaml code for the command_line sensor which does work, ideally I need to put the code into the value template to assign the input_boolean.
FYI this “toggle helper” input_boolean will not be editable on the front end, if shown it would be read-only (ideally only set from the below code). I have put some comments in there to show the direction I am trying to go - (so it does work as it now stands) -
- platform: command_line
command: "grep 'Fan Switched' /share/syslog | tail -1 | cut -c-255"
scan_interval: 30
command_timeout: 5
# value_template: >
# something like this->? {% input_boolean.rpi_fan_running.turn_{{ code in here for "on" or "off"? }}) %}
# or -
# something like this->? {% set_state('input_boolean.rpi_fan_running') = (value.string.find("Fan Switched ON") > -1)
# (Below is just to indicate we want the full unchanged string passed along in the command line
# sensor for now, later I might strip out the "Oct 5 11:36:50 kruse-pi fancontrol.py: " part of the
# string but I already know how to do that and will decide on that later)
# {{ value }}
unique_id: FAN_STATUS
(yes, the command_line is one of the few places where the unique ID can be specifically set which is very nice…)
Since I do refer to other sensors within some command_line sensor value_template code snippets I know they can be “read” - just hoping in the same place they can also be edited and are not “read-only” within this area (yikes)?
Ideas anyone? I am sure this shouldn’t be too hard…
