How to set fibaro multi sensor FGMS-001 Temperature report - threshold
how to set the “Temperature report - threshold” parameter number 60 from default setting = 10 to 2
on my Z-wave fibaro multi sensor FGMS-001 ?
i run home assistant via hass.io installed on a raspberry pi 3
thanks for your help
Configuration -> ZWave -> Choose the FGMS from the Node drop down -> Config Parameter drop down -> option number 60. Enter your chosen config parameter, and make sure to hit “set config parameter”
HTH
Many thanks for your help
