I have Home Assistant installed on a RaspberryPI 3B+. An 8 channel relay is connected to the GPIO pins as listed below. My problem is that when HA starts, all of the relays are active.
I have tested the relays and all work as advertised when a python script turns them on or off.
How do I change this so they will not be active when the Pi restarts?
Mike
Note: I am new at this so please bear with me.
…from the configuration.yaml file
GPIO setup
switch:
- platform: rpi_gpio
ports:
02: Garage Door
03: Lock Door
17: Unlock Door
27: Fan
22: Air Purifier
10: Patio Lights
09: Patio Fan
19: Patio Power
