How to Set Persistent "on_time" for Sonoff ZBMini Using Zigbee2Mqtt
Hi everyone,
I’ve recently set up the Sonoff ZBMini switch using Zigbee2Mqtt, and everything is working as expected.
According to the device’s specifications (SONOFF ZBMINI control via MQTT | Zigbee2MQTT), it’s possible to send the ON command with additional parameters, specifically “on_time” and “off_wait_time.” These parameters control how long the switch stays ON and the cooldown time before it responds to new timed ON commands.
I can successfully send an MQTT message, and the light turns off automatically after 3 seconds:
action: mqtt.publish
  qos: "0"
  topic: zigbee2mqtt/Luce Sala 1/set
  payload: "{\"state\" : \"ON\", \"on_time\" : 3}"
What I’d like to know is whether it’s possible to store the “on_time” value directly on the ZBMini so that the same behavior applies when the physical button is used to turn on the switch. Is there a way to make this setting persistent on the device?
I understand this could be easily achieved through a Home Assistant automation, but I’m looking for a solution that works independently of whether HA is running or not.
Thanks in advance for any tips or suggestions!
