How to set Piper speaking rate?
I’ve got Piper running as an internal Home Assistant add-on, and in companion with an external Whisper service, seems to function reasonably well for my satellite speaker.
The voice I’ve selected for Assist Text-to-speech is “alan (medium)”. Also good, though Alan enunciates a little slowly and carefully for our tastes.
I’ve tried to alter the Piper Add-on configuration settings to speed him up a little, changing from the default 1.0 setting to 0.75 (and now 0.65) and restarting Piper, but it doesn’t seem to have any effect.
Is there a way to adjust the Piper ‘length scale’ value directly within Assist?
Or, any other suggestion to adjust speech rate?
Thanks.
Hmm. Perhaps the length setting only affects custom sentences. Some of those on our system do seem to be a little too fast now.
However, an “I’m sorry, I do not understand that” is still overly slow.
I believe you have to clear the cache (tts.clear_cache) after adjusting the rate, otherwise it will just play back the previously-generated recording.
