If you go ha services, you will not see any available for persons, you have to use the API node to set the state via http POST.
You fill in the path /api/states/person.${name} and set the payload you wish to set, then push it with inject node.
This is a basic example
[{"id":"da33c165.0a6b9","type":"ha-api","z":"201f98bc.c1edd8","name":"","server":"d5ce5cec.92bc8","protocol":"http","method":"post","path":"/api/states/sensor.washing_machine_power","data":"","dataType":"json","location":"payload","locationType":"msg","responseType":"json","x":1590,"y":180,"wires":[[]]},{"id":"ebed1d51.afe99","type":"inject","z":"201f98bc.c1edd8","name":"100","topic":"","payload":"{\"data\":{\"state\":\"100\",\"attributes\":{\"unit_of_measurement\":\"W\",\"friendly_name\":\"Washing Machine Power\",\"icon\":\"mdi:power\"}}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":1420,"y":180,"wires":[["da33c165.0a6b9"]]},{"id":"d5ce5cec.92bc8","type":"server","z":"","name":"Home Assistant","legacy":false,"hassio":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true}]
Otherwise if the person is composed of device_trackers you can use the device_tracker.see service call
