How to set target in blueprint for service?
Hello!
I have a blueprint like:
input:
  thermostat:
    description: Thermostat
    selector:
        entity:
          domain: climate
variables:
  thermostat: !input thermostat
In the action, I want to set the temperature for this thermostat:
-service: climate.set_temperature
   temperature: 22
   hvac_mode: heat
     entity_id:
       - thermostat.entity_id
But nothing is happening when running an automation created with this blueprint. No error is shown as well. But when using the thermostat directly like this:
  entity_id:
    - climate.mythermostat
it works.
How do I have to set the target to make it adjustable and match the one from the input?
Added:
I tried various things like:
target: thermostat
or
target: !input thermostat
which resultet in Message malformed: expected a dictionary for dictionary value @ data[‘action’][0][‘then’][0][‘target’]
To use a variable like the one you created above, it goes within a template like this. You have the names overlapping which doesn’t cause an error, but is confusing. (I usually change the name slightly on a created variable to something like _thermostat.)
"{{ thermostat }}"
However I’m guessing this might work for your actual question:
- service: climate.set_temperature
    temperature: 22
    hvac_mode: heat
      entity_id:
        - !input thermostat
