In my HA I have integrated Homematic IP. All the entities are visible and used in cards (included wirh their serialnummbers). Only the central unit named HmIP-CCU3 doesn’t work fine.
I tried to insert the id into YAML-Code “Statusattribute” with: id: 9BE9A3C(etc.)
in the first line.
But this doesn’t work.
Please help.
Do you need more informationes?
Thank you for your answer.
The message is (translated):
This entity (“homematic.ccu3”) does not have a unique ID, so the settings cannot be managed via the UI.
My intention is to set a unique ID for the entity ‘homematic.ccu3’. But how to do this?
Yes you do. Some integrations are configured via the UI (user interface) some are configured with YAML (like yours), but they are both still integrations.
Please read the FAQ that Tinkerer linked to above.
Because there is none. You can file a feature request to have your integration provide unique_ids or, if you know some Python celebrate Hacktoberfest by contributing it yourself.
We still don’t know WHAT the problem is. You only say it “doesn’t work fine” but you don’t explain in what way it doesn’t work.
As for not being able to manage the device from the UI, it’s not clear what you want to manage, if you are just looking to change it’s name, you can do that in Customization in Home Assistant settings.
Typically, you’ll see this when you create entities manually using YAML, but it can also appear if the integration that provides this entity, cannot determine a unique ID. This however is not an error, but just a limitation of the integration you use.
Hello to all helpers
Many thanks for your all your comments and answers.
I think, that your are you’re right with the statement, that I don’t need more parameters for the entity ‘ccu3’. This is only the connector to all hardware and the lan.
(I’m new with HA, but I beleave in the concept and will work more to understand the details.)
