Many (financial) charts have the option to control the timeframe shown, like this one for example.
I want to do the same using ApexCharts, so I’ve made the chart shown in the picture at the bottom of my question.
The buttons above the chart all change a Text helper called input_text.timeframe to the value in their title (1h, 12h, 24h,…). These values are all accepted by the option graph_span as correct time strings.
I retrieve the string in the Text helper with this code:
{{ states (’ input_text. timeframe’) }}
Putting that code in developer tools returns the correct string: the text of the button last pressed.
However, that code does not work when inserted in ApexCharts, as shown below:
I can’t seem to find a solution for this problem.
(I’ve also tried every suggestion in this thread)
Does somebody have a solution for this? Many thanks in advanse.
