This guide walks through the initial setup of a Dusun DSGW-210 gateway running Home Assistant OS (HAOS). It covers first login, Zigbee2MQTT, Z-Wave JS UI, Bluetooth, Ethernet, Wi-Fi and LTE. It is intended for a gateway that already has HAOS installed.
Dusun’s earlier Home Assistant gateway used Debian with Home Assistant Supervised. The current DSGW-210-F-1-HA is supplied with HAOS pre-installed. Owners of earlier devices can find the “Home Assistant OS Firmware Update for DSGW-210-F-1-HA” entry on Dusun’s Software Updates page. We will publish separate flashing instructions for existing devices; this post covers setup after HAOS is running.
What you need
- The gateway, its power supply and an Ethernet connection for initial setup.
- A computer or phone on the same local network.
- An MQTT broker address and credentials if you plan to use Zigbee2MQTT.
- A SIM card if you plan to use LTE.
For the first startup, keep the gateway connected to the internet. Home Assistant may need time to download and install its components.
1. Find the gateway and complete Home Assistant onboarding
Connect the gateway to your router with Ethernet, then power it on. Find the IP address assigned to it in your router’s connected-device or DHCP list. In a browser on the same network, open:
http://<gateway-ip>:8123
Replace <gateway-ip> with the address assigned to your gateway. On first startup, you may see Preparing Home Assistant for some time. When the welcome screen appears, create your account and complete onboarding.
The Home Assistant welcome screen appears when the initial preparation is complete.
If the page does not open, verify the gateway’s IP address and Ethernet connection, then allow the initial installation more time. Do not use the IP address shown in another person’s screenshot; your router will assign its own address.
2. Install and configure Zigbee2MQTT
Zigbee2MQTT connects the gateway’s Zigbee coordinator to an MQTT broker. Prepare the broker before completing Zigbee2MQTT onboarding.
In Home Assistant, open Settings → Add-ons and then the Add-on Store. In newer Home Assistant versions, the interface may call add-ons Apps. Open the store menu, choose Repositories, and add:
https://github.com/zigbee2mqtt/hassio-zigbee2mqtt
Add the Zigbee2MQTT repository before searching for and installing the add-on.
Install Zigbee2MQTT. You can enable Watchdog and Show in sidebar, then start it and open its onboarding page. Enter the coordinator settings shown in the Dusun HAOS manual:
| Setting | Value |
| Coordinator/Adapter Port/Path | /dev/ttyUSB1 |
| Type/Stack/Driver | ember |
| Baudrate | 115200 |
Enter the coordinator settings in Zigbee2MQTT onboarding.
Next, set MQTT Server to your broker’s address. For example, if the broker is at 192.168.1.100, enter mqtt://192.168.1.100:1883. If it requires authentication, enter the MQTT username and password. The address in this example is only an illustration; use your broker’s actual address.
Use the address and credentials of your own MQTT broker.
Submit the configuration. If Zigbee2MQTT does not start, open Settings → Add-ons → Zigbee2MQTT → Log. Check whether the error concerns the coordinator connection or the MQTT broker, then troubleshoot that connection first.
3. Configure Z-Wave JS UI
In the Home Assistant add-on store, find and install Z-Wave JS UI. Enable Watchdog and Show in sidebar if desired, then start the add-on.
Select Z-Wave JS UI in the add-on store.
Open Z-Wave JS UI from the sidebar and go to its settings. Set the Serial Port to /dev/ttyS1, as specified in the Dusun HAOS manual. Select the RF Region appropriate to your deployment location, save, and check the add-on log to confirm that the controller starts.
The screenshot in the original manual also displayed Z-Wave security keys, so it is intentionally omitted here. Do not post your Z-Wave security keys or an unredacted screenshot of that settings page.
4. Add Bluetooth
Go to Settings → Devices & services. If Home Assistant discovers the Bluetooth adapter, select Add and complete the prompt. Otherwise, use Add integration, search for Bluetooth, and follow the on-screen steps. After setup, confirm that Bluetooth appears among the configured integrations before adding Bluetooth devices.
5. Configure Ethernet or Wi-Fi
Open Settings → System → Network.
For wired networking, select the Ethernet interface (eth0 in the manual). You can keep DHCP or enter a static IP configuration suitable for your network. For Wi-Fi, select the Wi-Fi interface (wlan1 in the manual), choose Search networks, select your network, enter its password and save.
Use Settings → System → Network to select and connect to a Wi-Fi network.
Changing the network interface or IP address may interrupt your current browser session. If that happens, find the gateway’s new address in your router and reopen Home Assistant at port 8123.
6. Start LTE, if you use a SIM card
Power off the gateway before inserting the SIM card. Insert the card, then power the gateway on again. According to the Dusun manual, LTE dialing starts automatically. Check the network status after startup to confirm that the cellular connection is available.
If a step does not work
Please include the gateway model, HAOS firmware version, the step where the problem occurs and the relevant text from the add-on log when asking for help. Remove passwords, security keys and other private information before posting. For Zigbee, the Zigbee2MQTT log will help distinguish coordinator errors from MQTT errors; for Z-Wave, check the Z-Wave JS UI log.
Dusun maintains the firmware and documentation for this gateway. We previously focused our support on B2B/OEM customers and recognize that individual Home Assistant users need clearer public instructions. We welcome corrections and reports from people following this guide on their own devices.
