Hey I added Shelly and can’t seem to make it appear. It’s the third generation one.
I added the code from the integration page, I put it under rpc over udp, and under outbound web socket. It still isn’t showing any data on my home assistant
You don‘t need nothing
Go in HA to device and than Shelly, put the IP from Shelly and than you see it
Make sure Shelly is in the same network as HA, either by wifi or cable (in case of Shelly PRO devices).
HA will automatically detect it under devices & services.
Okay turns out it was that my 2.4 and 5,ghz networks were bonded or whatever and I. Needed to name them manually. It works now.
