How to set up time trigger every two hours instead of every 2 oclock each day?
I can’t find any way to set up hourly intervals to trigger automation. Did I miss anything?
Use /2 instead of 2…this means "when divisible by 2. works w other integers too
Thank you, looks like working.
Would you kindly consider marking armedad’s post as the solution?
Doing so will close the topic and provide valuable assistance to others facing the same issue, allowing them to find a trusted solution when searching for a similar problem.
