How to set which view is default in Lovelace
In the most recent version. If I want to set one of my other tabs (views right?) as the default that loads first when I open HA web and iOS etc… How would I do that?
path: default_view
I thought that would work too, but I’m not having any luck. I set the new view to a path of default_view and old default to all. Rebooted too and no dice.
If you are using lovelace, try home-setter, I use it to set which view to be the default in each device.
I haven’t actually had to do this, I just noticed the option.
If it’s not working open an issue in the HA polymer section:
I couldn’t find an existing one for this.
FYI this seems to be resolved in .87 for me with the introduction of the view re-order GUI. The view in the first position is opening as default for me, regardless of path.
