How to set ZBMINI01 to rocker switch mode?
I’ve bought several ZBMINI01 and used them to control light and power outlets in my house. They work well if used with normal switches but as i tried to use them with the “rocker switch” option, they show a bad flaw. If the user presses the switch-button a bit too long, the ZBMINI thinks he is set to pulse-mode or following-mode and so the light turns off again after releasing the button.
Somebody told me that the Wifi variant could be set to a dedicated mode instead of autodetection. Maybe the Zigbee variant could do this as well. But in the cluster-config i can’t find a mode setting for this.
Does anybody know if it is available at all? Could it be that this setting is not integrated right now?
Have you tried pressing the little button on the zbmini 3 times to change its operating mode?
