How to setup a default dashbooard?
I created a second dashboard for my daughter. I did not want to see it, so I selected an option not to show it in a sidebar. My daughter does not have access to any other dashboard, just this one. The problem is that she cannot see it. I had to add this second dashboard to the sidebar, and she could switch and use it.
Is there any way to set it up as a default dashboard for her? I would like to remove it from my sidebar.
You should be able to set it under her profile, once logged in as her, click on the profile on the bottom left, and set dashboard what you want.
Thank you!
