I am new to the community but like to share how to use your Router internal DDNS for the Mobile APP and also HTTP Access.
- The first step will be to set up your DDNS features in your router. Most of the new +$50 routers have DDNS (Dynamic DNS) features with them but first, check your router spec sheet to make sure about it. I used ASUS and TP-Link, and both offer free DDNS for the router owners.
and they will give you a link like this sample: http://yourname.tplinkdns.com
- Reserve the IP Address. If you are using a static IP Address for your HA device you can go to the next step but if using a DHCP to assign an IP you need to set up an IP Address Reservation tor if to make sure it always will have the same IP address. To do this you will need the MAC address of your HA Device and the current IP and you should be able to find both of them in your DHCP list on your router webpage and then using them to set up an Address Reservation:
- Setup NAT forwarding. We need to set up a port forwarding to let the router know when it needs to forward the request to your HA device. To Setup that you will need an External Port (I used the same 8123 port that HA using for the internal communication but you can select a different port if you want) and then map it to your HA IP address and Port 8123. here is the setting for my Router
Now your network is ready to respond to the HA requests from outside without paying for the Cloud service. to connect to your system using an internet browser, you can use your DDNS address by adding the port you selected as the external port on your NAT Forwarding like this: http://yourname.tplinkdns.com:8123
To set it in your mobile APP you should go to “APP Configuration -> Connection -> Connection via” and used the same address for the external URL (Make sure also keep your internet URL setting)
Now enjoy your app everywhere
