I have a bunch of Z-Wave Multilevel-Sensors installed and integrated into HA via the ISY994i integration. I would like to display the current temp and humidity (and history) from these sensors in Lovelace. The Sensor Card seems to be the most apt way to do it, but I can’t seem to figure out how to get the Sensor card to read the particular attributes I want to display.
The entity contains the following data from the Developer Tools -> States lookup:
State: Unknown
State Attributes:
How can I get the Sensor Card to pick out the temperature (or humidity, or both) attributes instead of the “state” attribute? Must I create a fake sensor that tracks the underlying entity?
Thanks @tom_l. I was hoping to avoid that, but I guess not.
I wish there were a way to build a generic template that could then be parameterized. There are places where I have half a dozen (or more) entities that are exactly alike and need to be translated in exactly the same way I.e.,:
For the record, this is what I did (with an equivalent one for humidity), and it seems to be working (generally). However the sensor card is reporting “no history”. But honestly just using the default badge and the pop-up is good enough for what I want.
