Hello all,
I am using OwnTracks AND Home Assistant iOS App, they are both configured and working.
- I set up their friendly name to be the same on both
customize.yaml
andknown_devices.yaml
as, according toknown_devices.yaml
, they are recognised as two different devices. - I also added the same MAC address to both entries.
When I go to the map view on Home Assistant, I see two different icons showing at the same location. Is there any way to let Home Assistant know that they are indeed the same device? I assumed defining the same friendly_name
and same MAC address would do just that, but it does not.
Thank you for your help.
