How to show this marquee on a card?
coming from the Custom header showcase with some nice Marquee suggestions Custom Header template showcase and discussion I experience some system lag because of this always being on the screen.
Since I do like the marquee itself, Id like to try to get it on a dedicated card, Markdown as I post below, but that doesnt work nicely.
type: markdown
style: |
  ha-card {
  background: 'var(--paper-card-background-color)';
content: >
  {% set inside=states('sensor.temperatuur_living')%}
  {% set outside=states('sensor.temp_current')%}
  {% set temp_color='var(--primary-text-color)'%}
  {% set symbol='°C' %}
  <div style='display: flex;display: -webkit-flex;'>
  <div>Ha&nbspRpi4:&nbsp;</div>
  <marquee>
  <span style='color: {{ temp_color }}'>
  Inside temperature: {{ inside }}{{ symbol }},
  Outside temperature: {{ outside }}{{ symbol }},
  </span>
  <span style='color: orange;'>
  System alerts: {{states('sensor.marquee_alerts')}},
  </span>
  Summary - {{states('sensor.dark_sky_summary')}},
  Daily -  {{states('sensor.dark_sky_daily_summary').split('.')[0]}},
  Hourly - {{states('sensor.dark_sky_hourly_summary').split('.')[0]}}.
  </span>
  </marquee>
shows this unfortunately:
19
Would there be another card able to do this?
edit
found this marquee card ! by @ludeeus but it is unfortunately deprecated. I guess there would be no chance of you updating this? It is exactly what we need to get the marquee showing on a card, it almost does it already. Only thing buggy is it constantly resets, used with this config:
  - type: custom:marquee-state-element
    entity: sensor.marquee_alerts
    style:
      top: 10%
      left: 5%
      width: 100%
      max-width: 100%
would be a true unique card, allowing us to marquee, and preventing us from all the backend coding…
please have a look?
No, and it never was designed as a card, it is an element for the picture-elements card.
a that’s too bad, sorry to hear.
(for the sake of it tried it as prescribed on the picture-elements card, but it still makes it rather shaky, so not useful in its current state.)
Would you have a suggestion how to get a marquee in Lovelace otherwise please?
see Finally made my first marquee (on a custom: button-card) for the marquee I made based in all your input
