there are several posts discussing problems with TTS and I already tried serveral things to get TTS working, but without success.
For example:
Unfortunately, I didn’t find the folder /etc/letsencrypt in my HA Installation. I am using Hass.io followed the instructions from https://www.home-assistant.io/hassio/installation/. Maybe this is the solution? But where are these files?
All in all, TTS is not working, I dont know why. I am using Samba, DuckDNS with SSL (set up in configuration.yaml) and there are no errors in the logs.
I have a public domain and the SSL certificate isl valid. My configuration seems to be correct (I already tried some things from other posts discussing the TTS problems).
media id must be spotify
components/media_player/spotify.py (ERROR)
EDIT:
I am a fool. I cannot play TTS via spotify. I have to set up a media player, right?
But which media player? According to https://www.home-assistant.io/components/media_player/ I have to use one of these platforms?
Is it possible to add a speaker to my system running HA ? At the moment, I have only a echo dot and a Libratone Zipp…
