UchihaYuki
(Uchiha Yuki)
October 3, 2023, 3:48pm
1
My configuration:
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: GPIO16
num_leds: 2
rmt_channel: 0
# chipset: ws2812
bit0_high: 0.35us
bit0_low: 0.9us
bit1_high: 0.9us
bit1_low: 0.35us
When I compile, it complains:
But I can’t use ns either.
Esphome doesn’t support nanosecond resolution. Microseconds is the finest resolution you’re gonna get.
UchihaYuki
(Uchiha Yuki)
October 3, 2023, 4:48pm
4
Then how can I use esp32_rmt_led_strip?
Depends on what chipset your ledstrip uses. Which is?
nickrout
(Nick Rout)
October 3, 2023, 6:57pm
6
By following these instructions? ESP32 RMT LED Strip — ESPHome
UchihaYuki
(Uchiha Yuki)
October 4, 2023, 3:24am
7
It’s WS2812B, which has a different timing than WS2812.
UchihaYuki
(Uchiha Yuki)
October 4, 2023, 3:25am
8
I got the error by following these instructions.
nickrout
(Nick Rout)
October 4, 2023, 3:31am
9
What error?
Also if there is that much of a difference between ws2812 and ws2812b, then the b is not in the supported devices list.
UchihaYuki
(Uchiha Yuki)
October 4, 2023, 3:32am
10
Please read my post, I wrote the error there, and this is the timing diagram of both:
UchihaYuki
(Uchiha Yuki)
October 4, 2023, 3:35am
11
I don’t know what you mean. ws2812b doesn’t exist in the support list of esp32_rmt_led_strip, but it does exist in fastled_wireless, although, fastled_wireless doesn’t work on my board.
guzzzt
(Gustav Evertsson)
October 28, 2023, 12:28pm
12
The question is not about what chipset to use, it it about using the optional custom timing values.
I think this is a bug, there are no examples I can find that use the custom timing setting. The example in the original pull request (Create esp32 rmt addressable light driver by jesserockz · Pull Request #4708 · esphome/esphome · GitHub ) write it as
# Example config.yaml
light:
pin: GPIO27
num_leds: 1
chipset: SK6812
# bit0_high: 300us
# bit0_low: 900us
# bit1_high: 600us
# bit1_low: 600us
rgb_order: GRB
rmt_channel: 0
max_refresh_rate: 10ms
effects:
- addressable_rainbow:
- pulse:
So, they are off by a factor of 1000 (and only as a comment). All test yalm files are the same, either off by 1000 or comment.
The source code for setting these values are:
void ESP32RMTLEDStripLightOutput::set_led_params(uint32_t bit0_high, uint32_t bit0_low, uint32_t bit1_high,
uint32_t bit1_low) {
float ratio = (float) APB_CLK_FREQ / RMT_CLK_DIV / 1e09f;
// 0-bit
this->bit0_.duration0 = (uint32_t) (ratio * bit0_high);
this->bit0_.level0 = 1;
this->bit0_.duration1 = (uint32_t) (ratio * bit0_low);
this->bit0_.level1 = 0;
// 1-bit
this->bit1_.duration0 = (uint32_t) (ratio * bit1_high);
this->bit1_.level0 = 1;
this->bit1_.duration1 = (uint32_t) (ratio * bit1_low);
this->bit1_.level1 = 0;
But I can’t find where bit0_ and bit1_ are used, but I can’t say that I fully understand the source code.
Hi @UchihaYuki , were you ever able to find a resolution for this? I’ve just run into it myself with some WS2814 LEDs. Thanks!
