How to split data from serial sensor to sensor with attributes?
I try to use the serial printer output from a alarm system to monitor who goes in and out to try to setup automations and scripts in homeassistant to open or close a door lock or switch lights and music on or off when someone goes in or out.
I setup a sensor like:
  - platform: serial
    serial_port: /dev/ttyUSB0
    baudrate: 19200
    bytesize: 8
    parity: N
    stopbits: 1
    value_template: "{{
          'id': value[1:4],
          'date': value[14:22],
          'time': value[5:13],
          'door': value.split('op')[1].split('\x0e')[0].strip(),
          'user': value.split('gebruiker')[1][2:].split('\x0f')[0].strip(),
The sensor output without the value_template set is:
1283 22:19:01 18/08/20 Toegang verleend op Deur 1 voor gebruiker 2 Donald
How to create 1 sensor with attributes ‘id’ ‘date’ ‘time’ ‘door’ ‘user’ from it without creating multiple sensors?
Hope someone can point me in the right direction.
Regards,
Donald.
You will need to create a template sensor and add attributes using the attribute_template.
Thanks, will try it :slight_smile:
