dylan96
(Dylan Alpegiani)
October 23, 2019, 11:27am
1
Hello everyone, i’m trying to read data from a dht sensor connected to an arduino. I get a valid JSON data but i have no idea how to split it into two different sensors in hass.
This is what i did so far:
- platform: serial
serial_port: /dev/ttyUSB0
baudrate: 115200
value_template: "{{value_json}}"
sensors:
my_temperature_sensor:
friendly_name: Temperature
unit_of_measurement: "°C"
value_template: "{{ value_json.temperature }}"
my_humidity_sensor:
friendly_name: Humidity
unit_of_measurement: "%"
value_template: "{{ value_json.humidity }}"
can you help me? thanks
wellsy
(Steve Wells)
October 23, 2019, 11:42am
2
@dylan96 I’ve only done this for a DHT11 connected to a sonoff as an MQTT sensor but this may still work for yours…
- platform: mqtt
state_topic: "tele/sonoff17/SENSOR"
name: "Rumpus Temperature"
value_template: "{{ value_json.DHT11.Temperature }}"
- platform: mqtt
name: "Rumpus Humidity"
unit_of_measurement: "RH%"
value_template: "{{ value_json.DHT11.Humidity }}"
Hope that helps for your case?
petro
(Petro)
October 23, 2019, 11:53am
3
Unfortunately value_json data does not transfer from a state. It get’s turned into a string. Personally, If I were you, i’d do the following:
- platform: serial
baudrate: 115200
value_template: "{{ value_json.temperature }},{{ value_json.humidity }}"
sensors:
value_template: "{{ states('sensor.serial_temp_and_hum').split(',')[0] | float }}"
my_humidity_sensor:
value_template: "{{ states('sensor.serial_temp_and_hum').split(',')[-1] | float }}"
This will only have 1 serial call for 2 sensors. And you’ll easily split out the data without needing to use regex. Basically, what we are doing is making a comma separated state with temperature,humidity. Then in the template sensor we split on the comma and get the first item ([0] temperature), and the last item ([-1] humidity)
dylan96
(Dylan Alpegiani)
October 23, 2019, 12:20pm
4
Thank you this is exactly what I was looking for!
