How to start troubleshooting HA behavior with many errors
Sorry for the bad title and if there is a better spot to post this.
I’ve just noticed my Home Assistant is not behaving quite properly. Images for the users are not showing up, and HA will not load/display the history for anything. I’m sure there may be more issues, but that is all I see so far.
Should show user images:
I tried restarting, but got this:
Viewing errors, it looks like it started generating a crazy amount at about 2:03. I’ve been at work, and have not made any configuration changes.
I tried downloading the logs, but that gives me a 404 error. I will try to download them again locally when I’m home.
I’m lost and unsure of where to even start trying to address this. Any suggestions?
Hello Joshua R,
The second from the last might be a good one for you.
This has “corrupted storage” written all over it.
Tell us more about your hardware, especially if you’re running on an SD card
I’m running HA as a VM on an Unraid server.
Opening up the console for the VM I see this:
Which I assume also looks like corrupted storage.
I am unable to restart HA through the UI, view the configuration yaml, add new integrations, or even view add-ons at all.
Is there any danger in losing anything/everything if I try to force the VM to reboot?
If you have a recent backup, there is no danger. If you don’t, then I’d be a bit worried the restart will push the drive over the edge
Unfortunately I have not been responsible in keeping backups, that’s a lesson learned I suppose.
In Unraid, my drives all seem fine, but I will investigate further.
Your thought then is that it is a physical drive failed/failing?
It was my initial thought before you said you were on a VM.
Still wouldn’t exclude a failing drive, but I have no idea what other complexities Unraid might bring in
In case anyone comes to this for help in the future, the problem ended up being a failed RAM stick that causes corruption on my drive, which then was causing HA to misbehave.
