How to stop addons ui reloading?
Before I get a nervous breakdown…
How to stop the addons frontends to stop reloading every so often.
Especially Node-red, grafana and Studio code.
Not only having to se the reloadnig taking time, changes are buy buy unless I new I would be away long enough and save.
This is driving me nuts since it’s just a couple of minutes…
Go to your profile and turn off “Automatically close connection”
This will stop backgrounded tabs from closing their connection after 5 minutes. However…
It may also cause the repetition of this error:
Client exceeded max pending messages [2]: 512
I have turned off this setting and using Firefox I never see the error. I am careful to close all tabs when I am done with them though.
By the way, if you can open them in their own window rather than as an iframe, you also won’t this problem
Ah, seems like the best solution for someone like me, who are not good at closing tabs :wink:
Node-red was no problems, so now time for port-hunting :slight_smile:
Ah, thanks, it would be even better if one could set the timeout, since I’m not good at closing tabs, but will check what happens, using Vivaldi.
And do you happen to know if the timeout (or something else) has changed, because I can’t remember it beeing this annoying before, but I’ve had a sort of HA-hiatus fot quite a while.
No, it has always been 5 minutes.
