Good evening!
I have roller blinds with tuned automation to open/partially close depending on sun azimuth/elevation, cloud coverage etc.
However, I sometimes want to manually open/close the particular blind by setting the percentage using the slider in UI.
Is there any way to determine that position was set manually (and pause automation for like 2 hours) without adding any separate switches/flags into UI as it would be very inconvenient.
In short, I want Node red to know that the position was set manually via slider in UI (the rest is easy to do).
Just a brief idea is to make a logical slider not directly connected to roller and used as an indication of manual input, BUT in this case the question is 1) how to make it 2) how to make it to reflect the actual position of the roller set by automation 3) how to distinguish whether the difference between its valua and actual position of the roller was caused by manual input and not the automation changing the roller position right now. There should be more elegant solution…
Please help! Thanks in advance
Here’s the flow I have now…
[{"id":"eebabdea17bf9ae3","type":"tab","label":"Rollers","disabled":false,"info":"","env":[]},{"id":"26575e9e67e1e518","type":"inject","z":"eebabdea17bf9ae3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1800","crontab":"","once":true,"onceDelay":"0.5","topic":"","payload":"","payloadType":"date","x":170,"y":120,"wires":[["3c80c9fd97bc5c85"]]},{"id":"3c80c9fd97bc5c85","type":"function","z":"eebabdea17bf9ae3","name":"","func":"flow.set(\"hall1\", 180);\nflow.set(\"hall2\", 225);\nflow.set(\"hall3\", 260);\nflow.set(\"hall4\", 275);\nflow.set(\"hall5\", 330);\nreturn msg;","outputs":1,"noerr":0,"initialize":"// Добавленный здесь код будет исполняться\n// однократно при развертывании узла.\nif (flow.get(\"hall1\") === undefined) {\n flow.set(\"hall1\", 0);\n}\nif (flow.get(\"hall2\") === undefined) {\n flow.set(\"hall3\", 0);\n}\nif (flow.get(\"hall3\") === undefined) {\n flow.set(\"hall3\", 0);\n}\nif (flow.get(\"hall4\") === undefined) {\n flow.set(\"hall4\", 0);\n}\nif (flow.get(\"hall5\") === undefined) {\n flow.set(\"hall5\", 0);\n}\nif (flow.get(\"clouds\") === undefined) {\n flow.set(\"clouds\", 0);\n}\nif (flow.get(\"lightness\") === undefined) {\n flow.set(\"lightness\", 0);\n}\nif (flow.get(\"elevation\") === undefined) {\n flow.set(\"elevation\", 0);\n}\nif (flow.get(\"movement\") === undefined) {\n flow.set(\"movement\", 0);\n}","finalize":"","libs":[],"x":420,"y":120,"wires":[[]]},{"id":"7bc5e56f7c372fe8","type":"comment","z":"eebabdea17bf9ae3","name":"azimuth ranges and variables","info":"245 - закрываем center, left 50%","x":200,"y":60,"wires":[]},{"id":"7157213a4121eaaf","type":"time-range-switch","z":"eebabdea17bf9ae3","name":"","lat":"55.897368","lon":"37.464647","startTime":"07:30","endTime":"22:30","startOffset":0,"endOffset":0,"x":630,"y":300,"wires":[["f7fc78e9fd5f47c9","f84e62410783498c"],[]]},{"id":"375d1f43bbb676a4","type":"inject","z":"eebabdea17bf9ae3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"900","crontab":"","once":true,"onceDelay":"1","topic":"","payload":"","payloadType":"date","x":170,"y":300,"wires":[["fc6952d4759b40a4","82849d31dfbbc320"]]},{"id":"f7fc78e9fd5f47c9","type":"api-current-state","z":"eebabdea17bf9ae3","name":"","server":"9db60f84.2719c","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"weather.sweethome_2","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":910,"y":300,"wires":[["3699a5fdd69ee135"]]},{"id":"026236af82e0e144","type":"delay","z":"eebabdea17bf9ae3","name":"wait for 45 minutes","pauseType":"delay","timeout":"45","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1250,"y":300,"wires":[["7bd4e601b327b78c"]]},{"id":"3699a5fdd69ee135","type":"switch","z":"eebabdea17bf9ae3","name":"Cloudy?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"sunny","vt":"str"},{"t":"eq","v":"mostlysunny","vt":"str"},{"t":"eq","v":"partlysunny","vt":"str"},{"t":"eq","v":"partlycloudy","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":5,"x":980,"y":220,"wires":[["93e11aebea9ddf80"],["93e11aebea9ddf80"],["93e11aebea9ddf80"],["93e11aebea9ddf80"],["026236af82e0e144"]]},{"id":"7bd4e601b327b78c","type":"api-current-state","z":"eebabdea17bf9ae3","name":"","server":"9db60f84.2719c","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"weather.sweethome","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1580,"y":300,"wires":[["c2b1ad96ae5e74de"]]},{"id":"c2b1ad96ae5e74de","type":"switch","z":"eebabdea17bf9ae3","name":"Still?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"sunny","vt":"str"},{"t":"eq","v":"mostlysunny","vt":"str"},{"t":"eq","v":"partlysunny","vt":"str"},{"t":"eq","v":"partlycloudy","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":5,"x":1850,"y":300,"wires":[[],[],[],[],["9309af21caa9c984"]]},{"id":"9309af21caa9c984","type":"function","z":"eebabdea17bf9ae3","name":"Cloudy!","func":"flow.set(\"clouds\", 1);\nreturn msg;","outputs":1,"noerr":0,"initialize":"// Добавленный здесь код будет исполняться\n// однократно при развертывании узла.\nif (flow.get(\"hall1\") === undefined) {\n flow.set(\"hall1\", 0);\n}\nif (flow.get(\"hall2\") === undefined) {\n flow.set(\"hall3\", 0);\n}\nif (flow.get(\"hall3\") === undefined) {\n flow.set(\"hall3\", 0);\n}\nif (flow.get(\"hall4\") === undefined) {\n flow.set(\"hall4\", 0);\n}\nif (flow.get(\"hall5\") === undefined) {\n flow.set(\"hall5\", 0);\n}","finalize":"","libs":[],"x":2080,"y":300,"wires":[[]]},{"id":"93e11aebea9ddf80","type":"delay","z":"eebabdea17bf9ae3","name":"wait for 45 minutes","pauseType":"delay","timeout":"45","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1250,"y":220,"wires":[["6153d77bfc386b96"]]},{"id":"6153d77bfc386b96","type":"api-current-state","z":"eebabdea17bf9ae3","name":"","server":"9db60f84.2719c","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"weather.sweethome","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1580,"y":220,"wires":[["08e5a8d2edd45e7c"]]},{"id":"08e5a8d2edd45e7c","type":"switch","z":"eebabdea17bf9ae3","name":"Still?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"sunny","vt":"str"},{"t":"eq","v":"mostlysunny","vt":"str"},{"t":"eq","v":"partlysunny","vt":"str"},{"t":"eq","v":"partlycloudy","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":5,"x":1850,"y":220,"wires":[["0709715327f0f007"],["0709715327f0f007"],["0709715327f0f007"],["0709715327f0f007"],[]]},{"id":"0709715327f0f007","type":"function","z":"eebabdea17bf9ae3","name":"Not cloudy!","func":"flow.set(\"clouds\", 0);\nreturn msg;","outputs":1,"noerr":0,"initialize":"// Добавленный здесь код будет исполняться\n// однократно при развертывании узла.\nif (flow.get(\"hall1\") === undefined) {\n flow.set(\"hall1\", 0);\n}\nif (flow.get(\"hall2\") === undefined) {\n flow.set(\"hall3\", 0);\n}\nif (flow.get(\"hall3\") === undefined) {\n flow.set(\"hall3\", 0);\n}\nif (flow.get(\"hall4\") === undefined) {\n flow.set(\"hall4\", 0);\n}\nif (flow.get(\"hall5\") === undefined) {\n flow.set(\"hall5\", 0);\n}","finalize":"","libs":[],"x":2090,"y":220,"wires":[[]]},{"id":"a40829c734341660","type":"comment","z":"eebabdea17bf9ae3","name":"Clouds or not?","info":"Clouds or not","x":160,"y":200,"wires":[]},{"id":"ba9ddb7fe845a3cf","type":"comment","z":"eebabdea17bf9ae3","name":"is it really bright?","info":"Clouds or not","x":160,"y":480,"wires":[]},{"id":"6a8cc6d3100774e4","type":"function","z":"eebabdea17bf9ae3","name":"It's Bright","func":"flow.set(\"lightness\", 1);\nreturn msg;","outputs":1,"noerr":0,"initialize":"// Добавленный здесь код будет исполняться\n// однократно при развертывании узла.\nif (flow.get(\"hall1\") === undefined) {\n flow.set(\"hall1\", 0);\n}\nif (flow.get(\"hall2\") === undefined) {\n flow.set(\"hall3\", 0);\n}\nif (flow.get(\"hall3\") === undefined) {\n flow.set(\"hall3\", 0);\n}\nif (flow.get(\"hall4\") === undefined) {\n flow.set(\"hall4\", 0);\n}\nif (flow.get(\"hall5\") === undefined) {\n flow.set(\"hall5\", 0);\n}","finalize":"","libs":[],"x":1160,"y":580,"wires":[["e98780198c80b7b9"]]},{"id":"f84e62410783498c","type":"api-current-state","z":"eebabdea17bf9ae3","name":"Bedroom > 4000","server":"9db60f84.2719c","version":3,"outputs":2,"halt_if":"4000","halt_if_type":"num","halt_if_compare":"gt","entity_id":"sensor.bedroom_lightness","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":850,"y":580,"wires":[["6a8cc6d3100774e4"],[]]},{"id":"e98780198c80b7b9","type":"stoptimer","z":"eebabdea17bf9ae3","duration":"30","units":"Minute","payloadtype":"num","payloadval":"0","name":"Stoptimer for 30 minutes","x":1450,"y":580,"wires":[["2e9f0961fedc82ef"],[]]},{"id":"2e9f0961fedc82ef","type":"function","z":"eebabdea17bf9ae3","name":"Not anymore","func":"flow.set(\"lightness\", 0);\nreturn msg;","outputs":1,"noerr":0,"initialize":"// Добавленный здесь код будет исполняться\n// однократно при развертывании узла.\nif (flow.get(\"hall1\") === undefined) {\n flow.set(\"hall1\", 0);\n}\nif (flow.get(\"hall2\") === undefined) {\n flow.set(\"hall3\", 0);\n}\nif (flow.get(\"hall3\") === undefined) {\n flow.set(\"hall3\", 0);\n}\nif (flow.get(\"hall4\") === undefined) {\n flow.set(\"hall4\", 0);\n}\nif (flow.get(\"hall5\") === undefined) {\n flow.set(\"hall5\", 0);\n}","finalize":"","libs":[],"x":1690,"y":580,"wires":[[]]},{"id":"019744cab4f1148a","type":"comment","z":"eebabdea17bf9ae3","name":"is the sun up?","info":"Clouds or not","x":150,"y":700,"wires":[]},{"id":"fc6952d4759b40a4","type":"api-current-state","z":"eebabdea17bf9ae3","name":"","server":"9db60f84.2719c","version":3,"outputs":2,"halt_if":"above_horizon","halt_if_type":"str","halt_if_compare":"is","entity_id":"sun.sun","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":420,"y":300,"wires":[["7157213a4121eaaf","12b1e2cb52eba8b0"],[]]},{"id":"520f59c5bdd00432","type":"change","z":"eebabdea17bf9ae3","name":"Sun is high enough","rules":[{"t":"set","p":"elevation","pt":"flow","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":760,"wires":[[]]},{"id":"12b1e2cb52eba8b0","type":"switch","z":"eebabdea17bf9ae3","name":"Elevation > 10deg","property":"data.attributes.elevation","propertyType":"msg","rules":[{"t":"gt","v":"10","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":610,"y":780,"wires":[["520f59c5bdd00432"],["58987404832c6285"]]},{"id":"58987404832c6285","type":"change","z":"eebabdea17bf9ae3","name":"Sun is low enough","rules":[{"t":"set","p":"elevation","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":800,"wires":[[]]},{"id":"5e0a72b37afe2551","type":"comment","z":"eebabdea17bf9ae3","name":"Should we close blinds on schedule?","info":"Clouds or not","x":220,"y":960,"wires":[]},{"id":"82849d31dfbbc320","type":"time-range-switch","z":"eebabdea17bf9ae3","name":"","lat":"55.897368","lon":"37.464647","startTime":"05:30","endTime":"23:30","startOffset":0,"endOffset":0,"x":390,"y":1040,"wires":[["9577b4dc05585d02"],["5a1fe6e401547958"]]},{"id":"9577b4dc05585d02","type":"switch","z":"eebabdea17bf9ae3","name":"Elevated?","property":"elevation","propertyType":"flow","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":580,"y":1040,"wires":[["73b49eda856c2cdb","744996fa0d59d469"],["5a1fe6e401547958"]]},{"id":"73b49eda856c2cdb","type":"switch","z":"eebabdea17bf9ae3","name":"Bright?","property":"lightness","propertyType":"flow","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":780,"y":1020,"wires":[["0f253ac07b1b089e"],["49bedd1996d67289"]]},{"id":"c9ec0e0c398a1870","type":"sunrise","z":"eebabdea17bf9ae3","name":"","lat":"55.897368","lon":"37.464647","start":"dawn","end":"goldenHour","soff":0,"eoff":0,"x":110,"y":1860,"wires":[[],["31ca9fdbb1f2eb21"]]},{"id":"744996fa0d59d469","type":"switch","z":"eebabdea17bf9ae3","name":"No clouds?","property":"clouds","propertyType":"flow","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":790,"y":1060,"wires":[["0f253ac07b1b089e"],["758a65b2824c9380"]]},{"id":"5a1fe6e401547958","type":"change","z":"eebabdea17bf9ae3","name":"Dont move!","rules":[{"t":"set","p":"movement","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":1260,"wires":[[]]},{"id":"0f253ac07b1b089e","type":"change","z":"eebabdea17bf9ae3","name":"Lets move!","rules":[{"t":"set","p":"movement","pt":"flow","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1430,"y":1020,"wires":[[]]},{"id":"31ca9fdbb1f2eb21","type":"debug","z":"eebabdea17bf9ae3","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":350,"y":1860,"wires":[]},{"id":"758a65b2824c9380","type":"change","z":"eebabdea17bf9ae3","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"path_1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":1140,"wires":[["94fdb5ea666442d4"]]},{"id":"94fdb5ea666442d4","type":"join-wait","z":"eebabdea17bf9ae3","name":"","paths":"[\"path_1\", \"path_2\"]","pathsToExpire":"","useRegex":false,"warnUnmatched":true,"pathTopic":"topic","pathTopicType":"msg","correlationTopic":"","correlationTopicType":"undefined","timeout":"10","timeoutUnits":"1000","exactOrder":"false","firstMsg":"true","mapPayload":"false","disableComplete":false,"persistOnRestart":false,"x":1260,"y":1160,"wires":[["5a1fe6e401547958"],[]]},{"id":"49bedd1996d67289","type":"change","z":"eebabdea17bf9ae3","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"path_1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":1180,"wires":[["94fdb5ea666442d4"]]},{"id":"485e24a5b24e1217","type":"comment","z":"eebabdea17bf9ae3","name":"Actual roller movement","info":"Clouds or not","x":140,"y":1540,"wires":[]},{"id":"cf44f6e406f4875b","type":"inject","z":"eebabdea17bf9ae3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"900","crontab":"","once":true,"onceDelay":"1","topic":"","payload":"","payloadType":"date","x":130,"y":1600,"wires":[["1160308127fd84d2"]]},{"id":"9609f205263d5cd7","type":"api-current-state","z":"eebabdea17bf9ae3","name":"","server":"9db60f84.2719c","version":3,"outputs":2,"halt_if":"above_horizon","halt_if_type":"str","halt_if_compare":"is","entity_id":"sun.sun","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":880,"y":1600,"wires":[["bf45362fb265c76a"],[]]},{"id":"2307f4aa4bd23a56","type":"switch","z":"eebabdea17bf9ae3","name":"Should we close?","property":"movement","propertyType":"flow","rules":[{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":590,"y":1600,"wires":[["9609f205263d5cd7"],["f0401bafb3771e33"]]},{"id":"1160308127fd84d2","type":"change","z":"eebabdea17bf9ae3","name":"movement?","rules":[{"t":"set","p":"payload","pt":"msg","to":"movement","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":1600,"wires":[["2307f4aa4bd23a56"]]},{"id":"bf45362fb265c76a","type":"switch","z":"eebabdea17bf9ae3","name":"ranges of azimuths","property":"data.attributes.azimuth","propertyType":"msg","rules":[{"t":"btwn","v":"hall1","vt":"flow","v2":"hall2","v2t":"flow"},{"t":"btwn","v":"hall2","vt":"flow","v2":"hall3","v2t":"flow"},{"t":"btwn","v":"hall3","vt":"flow","v2":"hall4","v2t":"flow"},{"t":"btwn","v":"hall4","vt":"flow","v2":"hall5","v2t":"flow"},{"t":"gt","v":"hall5","vt":"flow"}],"checkall":"true","repair":false,"outputs":5,"x":1130,"y":1600,"wires":[["043b659ffdb5fcb0"],["26b887cea393b9fa"],["e706865fa21411cc"],["225bb9cc8d6d4050"],[]]},{"id":"043b659ffdb5fcb0","type":"function","z":"eebabdea17bf9ae3","name":"1","func":"var HL = {payload: \"20\", topic: \"1\"};\nvar HC = {payload: \"70\", topic: \"2\"};\nvar HR = {payload: \"30\", topic: \"3\"};\nvar KL = {payload: \"0\", topic: \"4\"};\nvar KR = {payload: \"70\", topic: \"5\"};\nreturn [HL, HC, HR, KL, KR];","outputs":5,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1530,"y":1480,"wires":[["975c9ac437a68b43"],["7eb6df8f9736df14"],["4217dbf7bf193e91"],["3d418b538ef3d60e"],["ce83bd7eeaf49e5d"]]},{"id":"2a3a56b9a2a5d1a5","type":"api-call-service","z":"eebabdea17bf9ae3","name":"center_position","server":"9db60f84.2719c","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":["c3f9bfef584a8243178ef64304fdba09"],"entityId":["cover.0x00158d0007007abb"],"data":"{ \"position\": msg.payload}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2080,"y":1580,"wires":[[]]},{"id":"bd58eb043ce09b07","type":"api-call-service","z":"eebabdea17bf9ae3","name":"left_position","server":"9db60f84.2719c","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":["fbb3c2d4997fac54fab6bf37d1286bf3"],"entityId":["cover.0x00158d00069c5f26"],"data":"{ \"position\": msg.payload}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2070,"y":1540,"wires":[[]]},{"id":"5f5f392bd649313a","type":"api-call-service","z":"eebabdea17bf9ae3","name":"right_position","server":"9db60f84.2719c","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":["538f4173f8b33a605bf1610757932b52"],"entityId":["cover.0x00158d0007073978"],"data":"{ \"position\": msg.payload}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2070,"y":1620,"wires":[[]]},{"id":"b7375a44dc2249af","type":"comment","z":"eebabdea17bf9ae3","name":"Hall","info":"Clouds or not","x":2050,"y":1480,"wires":[]},{"id":"ae720925b8eab1f4","type":"comment","z":"eebabdea17bf9ae3","name":"Kids","info":"Clouds or not","x":2050,"y":1680,"wires":[]},{"id":"bd7449b5fd55c7d7","type":"api-call-service","z":"eebabdea17bf9ae3","name":"right_position","server":"9db60f84.2719c","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":["7d497ddacdaecdccecccf4e972381082"],"entityId":["cover.0x00158d0007012bed"],"data":"{ \"position\": msg.payload}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2070,"y":1800,"wires":[[]]},{"id":"f7d698d317a53774","type":"api-call-service","z":"eebabdea17bf9ae3","name":"left_position","server":"9db60f84.2719c","version":5,"debugenabled":false,"domain":"cover","service":"set_cover_position","areaId":[],"deviceId":["ce6b920a3284020e2f9b12c19ccc18a7"],"entityId":["cover.0x00158d0007007a91"],"data":"{ \"position\": msg.payload}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":2070,"y":1740,"wires":[[]]},{"id":"26b887cea393b9fa","type":"function","z":"eebabdea17bf9ae3","name":"2","func":"var HL = {payload: \"40\", topic: \"1\"};\nvar HC = {payload: \"0\", topic: \"2\"};\nvar HR = {payload: \"60\", topic: \"3\"};\nvar KL = {payload: \"20\", topic: \"4\"};\nvar KR = {payload: \"20\", topic: \"5\"};\nreturn [HL, HC, HR, KL, KR];","outputs":5,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1530,"y":1600,"wires":[["975c9ac437a68b43"],["7eb6df8f9736df14"],["4217dbf7bf193e91"],["3d418b538ef3d60e"],["ce83bd7eeaf49e5d"]]},{"id":"e706865fa21411cc","type":"function","z":"eebabdea17bf9ae3","name":"3","func":"var HL = {payload: \"80\", topic: \"1\"};\nvar HC = {payload: \"0\", topic: \"2\"};\nvar HR = {payload: \"100\", topic: \"3\"};\nvar KL = {payload: \"80\", topic: \"4\"};\nvar KR = {payload: \"50\", topic: \"5\"};\nreturn [HL, HC, HR, KL, KR];","outputs":5,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1530,"y":1700,"wires":[["975c9ac437a68b43"],["7eb6df8f9736df14"],["4217dbf7bf193e91"],["3d418b538ef3d60e"],["ce83bd7eeaf49e5d"]]},{"id":"225bb9cc8d6d4050","type":"function","z":"eebabdea17bf9ae3","name":"4","func":"var HL = {payload: \"100\", topic: \"1\"};\nvar HC = {payload: \"100\", topic: \"2\"};\nvar HR = {payload: \"100\", topic: \"3\"};\nvar KL = {payload: \"100\", topic: \"4\"};\nvar KR = {payload: \"100\", topic: \"5\"};\nreturn [HL, HC, HR, KL, KR];","outputs":5,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1530,"y":1800,"wires":[["975c9ac437a68b43"],["7eb6df8f9736df14"],["4217dbf7bf193e91"],["3d418b538ef3d60e"],["ce83bd7eeaf49e5d"]]},{"id":"f0401bafb3771e33","type":"change","z":"eebabdea17bf9ae3","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"100","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1470,"y":1900,"wires":[["975c9ac437a68b43","7eb6df8f9736df14","4217dbf7bf193e91","3d418b538ef3d60e","ce83bd7eeaf49e5d"]]},{"id":"975c9ac437a68b43","type":"rbe","z":"eebabdea17bf9ae3","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":1890,"y":1540,"wires":[["bd58eb043ce09b07"]]},{"id":"7eb6df8f9736df14","type":"rbe","z":"eebabdea17bf9ae3","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":1890,"y":1580,"wires":[["2a3a56b9a2a5d1a5"]]},{"id":"4217dbf7bf193e91","type":"rbe","z":"eebabdea17bf9ae3","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":1890,"y":1620,"wires":[["5f5f392bd649313a"]]},{"id":"3d418b538ef3d60e","type":"rbe","z":"eebabdea17bf9ae3","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":1890,"y":1740,"wires":[["f7d698d317a53774"]]},{"id":"ce83bd7eeaf49e5d","type":"rbe","z":"eebabdea17bf9ae3","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":1890,"y":1800,"wires":[["bd7449b5fd55c7d7"]]},{"id":"9db60f84.2719c","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":""}]
