StefanKl
(Stefan)
1
Dear all,
I am running HomeAssistant under Docker on DSM 7.0. To avoid frequent HDD access, I want to disable docker logging. But how to do so?
I modified both the
/var/packages/Docker/etc/dockerd.json
to
“log-driver” : “none”
and the
containers’s json config file uploaded to the Docker GUI (see this post)
adding
“log-driver”: “none”,
but to no effect. Docker still stubbornly writes every five minutes or so into containerID/log.db.
Please help
Best,
Stefan
StefanKl
(Stefan)
2
Solved.
Documentation:
Place files docker-compose.yml and resolv.conf (see below) e.g. into /volume1/docker/homeassistant
Then via Terminal:
$ cd /volume1/docker/homeassistant
$ sudo -i
docker-compose up -d
docker-compose.yml:
version: “3.9”
services:
home_assistant:
container_name: homeassistant
restart: always
image: homeassistant/home-assistant:latest
volumes:
- /tmp/homeassistant/config:/config
environment:
- TZ=Europe/London
network_mode: host
logging:
driver: none
resolv.comf
nameserver 192.168.178.1
nameserver 8.8.8.8
domain fritz.box
